Question about Intel Motherboard
Foxconn 661M03C-6L MB and Pentium P4 1.8GHz Processor
This MB runs perfectly with a 3.2GHz P4 but does not boot up with a 1.8GHz. Could you advise please if the MB supports a 1.8GHz P4 or if some settings need to be changed.
Many thanks
Bob
Tumhari mah ki choot
Posted on Aug 05, 2008
Does anyone know where i can obtain the drivers for this motherboard?
Posted on Mar 24, 2008
    Novelist:
  • 113 Answers
I suspect the issue is that the 1.8 uses a 400Mhz system bus speed, and the mobo likely only supports 533 and 800.
Posted on Feb 01, 2008
Foxconn 661FXME - PC661M04-G-6L & Intel pentium 4 prescott 511 2.80 ghz
Hello you can download a manual from here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000108&Language=en-us
But BE CAREFULL when you change the cpu.
And remember to add some cooling paste.
Here is some info about the cpu:
http://ark.intel.com/products/27452/Intel-Pentium-4-Processor-511-1M-Cache-2_80-GHz-533-MHz-FSB
You will get better performance with a new mainboard/cpu
as this cpu only has one core.
Good luck
Oct 06, 2012 | Null Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
My board is foxcon 661m03c-mx-6l usb not work
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
don
Feb 18, 2011 | Foxconn 661M03-G-6EL Motherboard
I need foxconn 661m03c-mx-6l drivers plz
http://www.foxconnsupport.com/download.aspx?models=en-us0000280&category=C000000001&Series=en-us0000001&keywords=&sort=
Aug 03, 2010 | Intel Computers & Internet
WHAT KIND OF PROCESSOR COMPATIBLE TO FOXCONN P4M800MO1
you can enter in your Mb any type of intel processors ranging max speed bus 800 mhz , for example you can enter intel pentium 4 hyperthreading 3.00 ghz , 800 mhz front side bus 1 mb cache, number 530, 530 j or better than him.
Apr 08, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Foxconn board
the problem is software, there is nothing wrong with the processor as the machine boots showing that the processor works, have a look at your memory and clean it.
This problem occurs because there is a limited amount of kernel space available for kernel drivers so there is not enough stack space for processing the exception. its an operating system problem, try and boot into safe mode and perform a system restore by pressing F8 on boot up
good luck
Nov 14, 2008 | Foxconn Computers & Internet
Foxconn motherboard 650m02-g-6l error signal
I would recommend buying a new stick of RAM at your local store. If it does not work, as long as it is not damaged, most places will take it back without a restocking fee. If it does work, then your good to go!
If it does not work, then there may be a problem with the actual RAM slot on the motherboard,
Sep 03, 2008 | Foxconn 650M02-G-6L Motherboard
I want a sound card driver
necesito driver de una foxconn 661m03c-mx-6l
Jul 02, 2008 | Computers & Internet
FOXCONN K7S741GXMG-6L
AMD 2800+ is 333MHZ while
AMD DURON 120MHZ is just 200 MHZ
It means that the board supports 333MHZ not 200MHZ.
Well it's not compatible...
Jan 27, 2008 | Foxconn K7S741GXMG-6L Motherboard
Intel Motherboard Logo
3,777 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
