Question about KitchenAid Superba KFRS271TSS Stainless Steel Gas Grill
Flame height on one burner decreased! - KitchenAid Superba KFRS271TSS Stainless Steel Gas Grill
    President:
  • 1,304 Answers
You need to clean your difusser for that burner,
its probably have gunk built up on it
Posted on Oct 05, 2009
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Flame height on my 36 " 6 burner Viking Range Top
remove the knob, the center shaft is hollow, slide in a small blade screw driver to adjust the flame cheers
Dec 11, 2013 | Viking VGRT360-6B 36 in. Gas Cooktop
I replaced the burners, part #80018594, in my Commercial series grill. Do I need to adjust them?
Normally, I would say know, if they are exact replacements. However, the only way to know is after you light the burners and check the flame colors and heights. For propane gas burners, the screw on each burner should be all the way in. For Natural Gas, about 2/3rd's of the way in.
If you tank has bee turned OFF during repair. Open the tank valve VERY, VERY SLOWLY aSlow Motion, slow) until the valve is fully open. Then light the burner farthest from the tank first and turn it to high. Does the flame height and color look correct? If so, light the remaining burners the same way. Do all the flame heights and colors look correct? If so, you're ready to start grilling with your new burners.
If not, turn the burners OFF and Let them cool completely, before making any adjustments.
Hope this helped you. Please let me know and Happy grilling!!
May 28, 2011 | Char-Broil Commercial Stainless Steel...
Gas fire place flame to low, do you have a schematic to increase the flame ?
Generally, whether it's a Vent-free or Vented fireplace, lower than normal flame height is caused by 3 things: Low Gas pressure; The air shutter control valve is clogged or needs adjusting; The burners need cleaning.
I haven't seen a unit in the past 10 years, that has a flame height adjustment, other the flame height control knob, that's part of the control assembly. Have you checked that, to see what height it's turned to low?
Perhaps, if I knew who the manufacturer was and the model number, I could be of more help to you.
Mar 15, 2011 | Honeywell Heating & Cooling
Gas Flow Problem
Replace the regulator and hose assembly that screws onto the propane bottle. I had the same problem on two patio heaters and my 4 burner grill. You can get regulators and hose at Home Depot, Lowes, Northern, probably Meijers, etc. Check the fitting on the end of the hose for the correct gender, male or female, size, and hose length. You can get a fitting in the plumbing department to change the gender.
I can all but give you money that this will fix it.
Jan 15, 2009 | Char-Broil Performance 463463006
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Kenmore 32099 Cooktop burners regulation
remove the burners and adjust the air ration with the slide at the bottom of the burner tube
Jul 25, 2007 | Kenmore 30 in.32099 / 32094 / 32092 Gas...
Burner Problem
it appears that the air intake intake is incorrectly set or you have the incorrect gas jets fitted to the product. Regards Engineer
Jun 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
KitchenAid Superba KFRS271TSS Stainless Steel Gas Grill Logo
124 people viewed this question
Top KitchenAid Grilling Experts
paulcarew
Paul Bade
Bill Boyd
Are you a KitchenAid Grilling Expert? Answer questions, earn points and help others
