Question about Intel Motherboard
Nothing get displyaed once pc on
I have cleaned my pc ....
after reassembling all when i connected to ups its automatically switching on ...
any one know about the mother board front panel 1 ---- 12 pins details [ power switch , reset sw , etc -- i dont know about this -- not connected - may be due to this its switching on itself ]
but after that no display in the monitory .. atleast bios should come up right . i have tried by cleaning ram - inserting againg -etc nothing works out ..
will there be any bios chip failure .... or corruuption .. process is getting heated up like anything . any soultion for this ...
  • 700 Answers
You should tag and do some sketch when you disconnect the wiring on the board first. But a manual could greatly help you now. That could be you interchange the connections.
If connection is right, you can try to unplug and replug the BIOS battery for the automatic switching of the board. And check the RAM and video card, and also other add in card.
Goodluck
Posted on Oct 05, 2009
  • 212 Answers
Try and find the installation manual for the exact model of system board and verify if the front panel connectors on the system board have been connected correctly. i suspect you might have inversed the power btn and power led cables. if this is not the case, then you might want to reset your power management settings in the BIOS setup.
My desktop was fine last night but today will only power up for 1 or 2 seconds and switches off again,any ideas please?
psu replaced with known good power supply no change
cmos either reset or pull the battery to reset it no change
checked motherboard led for power. power supply led for power.
then start unplugging things from the motherboard. any cards plugged into slots checking each time to see if it powers up. was there a storm that could fry one of them.
Aug 23, 2015 | Computers & Internet
MY nEP[TUNE WASHER WONT STOP RUNNING WASTER
Ok there are 2 possibilities that cause this problem. 1) If the drain pipe is placed to low, the water will not stop draining. It will just carry on coming into the machine and just flow out again. Make sure the pipe is at least 3/4 the height of the machine before that draining will stop. 2) If you switch the power off on the washer, and the water still comes into the unit with the power switched off,then the water solonoid needs to either be serviced or replaced. With the plug pulled out, undo the 2 water pipes connected to the water valve assembly.Once removed, open the individual valves and clean them properly. once cleaned, reassemble and retry. Either of those 2 must work. My bet is the water pipe is to low. lift it up a lot higher.
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How to replace a brake switch sensor on a honda accord 2001
Just pulled out and cleaned it up as the van would not come out of park even with the brake pedal pressed, and the break lights were not working. To remove get a small flashlight and move the driver's seat all the way to the rear to give you room to move around. looking at the break pedal with the flashlight follow the pedal arm up and you will see a electrical stop switch located about 3 or 4 inches up from the break pedal.
To remove unplug the connected wires from the switch. You will need to push down on the locking lever on the socket to pull the socket from the plug. Once the wiring is removed simply grasp the switch body and rotate counter clock wise about 45 degrees and the switch will pull straight out of the socket. No wrenches required, nothing. Mine rotated with light pressure and pulled straight out. You can purchase a replacement or as I did I disassembled mine and cleaned the contact points and reassembled and it worked fine.
Good luck (remember comment and rated this).
Jul 12, 2010 | Cars & Trucks
My acer aspire 5920 is completley dead it will not turn on with a fully charged battery which was charged up using a second 5920, it will not turn on with a working power supply either. I have completly...
Might your switch be non-functioning? Can you check that independently?
Otherwise, sounds to me like you did eveything.
Same thing happened to me with my dog once. I let him out and that was it! :-)
Oct 09, 2009 | Acer Aspire 5920-6727 Notebook
Automatic oiler won't oil chain.
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 03, 2009 | Garden
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
My Zen Vision M 30GB mp3 player won't turn on, the blue light at the top flashes but the screen won't pop up, not even when i plug it in to charge it (which it usually does automatically). Now, i tried to...
Mine does the same thing, You just have to leave it plugged in for a long time, and after a while the black screen with the battery that tells you it's charging will show up.
Trust me, it'll happen.
Jul 20, 2009 | Creative Labs ZEN Vision:M Digital Media...
Coobra DC125
hello.
after connecting the camera, windows did not pop up that the camera is detected. maybe it need to switch on the camera, because there are some camera that need to switch on and then the pc detect it automatically.
tell me more about the camera issue when connecting to PC. please do not rate me until i solve the problem, melnavz
Apr 01, 2008 | Cobra DC4200 Digital Camera
Intel Motherboard Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
