Question about HP Compaq nc6320 Notebook
Will not power up when I plug the power cord in
When I plug my power cord and press the power up button the computer will not power up.
  • 383 Answers
No display on monitor. If you are not receiving power from a known working wall outlet and if the power cord is removable, replace it with the one connected to the computer .
Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 22, 2007
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
Sep 05, 2011 | Acer Aspire 7740G6364 (lxplx02165) PC...
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
BOOTING PROBLEM
If the computer will not power on:
  1. Make sure the power cord or AC adapter is plugged into the computer and into an electrical outlet that is live.
  2. If it is plugged into a power strip or surge protector make sure it is powered on.
  3. Try using a different electrical outlet.
  4. Check voltage setting on power source (AC Adapters are auto switching).
  5. Perform a power reset on the computer.
To perform a power reset:
  1. Unplug and remove the AC adapter and battery, or power cable from the computer.
  2. Press and hold the power button on the computer for about 30 seconds.
  3. Release the power button and plug the AC adapter and battery, or power cord back into the computer.
  4. Press the power button and see if the computer powers up.
  5. If that does not work, try a different AC adapter, battery, or power cable and repeat these steps.
If the problem persists the computer may need service. You may need to contact Acer support.
Nov 24, 2010 | Acer Aspire 5100 Notebook
There is no power from the battery or the adapter and the laptop does not recognise the adapter is plugged in. there are no lights coming on and the power button is doing nothing
Your battery maybe out of charge. Thats why nothing happens when you press the power button. The battery may not be charging because the power cord might not be working. Try another power cord.
Try removing the battery and plugging the power cord and switching on the computer. If its the problem with the power cord the computer wont start. If it starts, the power cord is working fine.
Nov 18, 2010 | Acer Aspire 5920-6727 Notebook
My HP Pavilion M90 monitor won't turn on. Every time I press the on button I hear a clicking sound from the back of the monitor. It sounds like it's trying to power up but it doesn't do anything. Is there...
Hello
Do a hard reset on the laptop by removing all cords and connections from the computer, including the power cord. Turn the computer over and slide the tab next to the battery, then lift the battery out of its compartment.
Eject any SD cards currently inserted in the SD card slot by pressing on them, then remove them from the slot completely. Hold the computer's "Power" button down for at least 15 seconds, then plug the power cord into the computer and turn it on.
Watch to see if the LED lights near the "Caps Lock" and "Num Lock" illuminate. If the lights do not turn on and the computer's screen remains blank, inspect the power cord and AC adapter for damage and replace them if necessary.
Leave the power cord plugged into the computer and snap the battery back into its slot. Allow the computer to sit for at least 30 minutes, then unplug the power cord and press the "Power" button again to see if the computer will turn on.
Plug the power cord back into the computer and try to turn it on again. If the computer turns on, replace the battery with a new one. If the computer still does not turn on, take the computer to a repair shop.
Oct 04, 2010 | HP Pavilion M90 Monitor
My printer is showing error oxdo5do1od recycle power how can i over come that
Please perform the following steps:
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
Carriage jam, load paper, 2575 won't print
Step1:
  1. Turn off the HP All-in-One by pressing the On button on the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the On button on the HP All-in-One.
If the issue persists, then
Unplug the power cord from the all-in-one. Press and hold # and 3 while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+ ) instead of # . Press and hold the button combination for your all-in-one. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
Unplug the power cord from the all-in-one. Press and hold # and 6 while plugging in the power cord. if you are unable to perform this leave it and get back to us.
Aug 27, 2009 | HP Photosmart 2575 All-In-One InkJet...
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
HP Compaq nc6320 Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
