Question about Dell 1710 Laser Printer
Dell Laserjet 1710 - won't take the paper from the tray
I have a Dell Laserjet 1770. It suddenly won't take the paper from the tray and I don't know what the problem is! There appears to be no paper jam.
  • 330 Answers
Clean the paper pick up roller and check any paper pieces is there
Posted on Oct 05, 2009
The paper jams half way through
I would remove the paper tray, inspect the area carefully and look for debris in the area, i.e. paper clip, staple, rolled up paper etc. Then do the same thing for the area where the paper exits. If you are able to turn the rollers by hand, the offending item may expose itself.
Jan 20, 2015 | Dell 1710 Laser Printer
Tip
Dell 1700 1710 series printer. Paper not picking up trick....
Here's a quick tip. If your Dell 17XX series (not confirmed for newer than 1710dn printers) is no longer picking up paper from the tray, it MAY be from worn out rollers. Try this tip to get it going while you wait for a replacement roller to get to you:
1 - remove the paper tray
2 - remove toner
3 - flip printer upside down (exposing the rollers)
4 - remove the rubber on the roller
5 - invert it. (turn it inside out)
6 - replace rubber back onto roller (still inverted)
7 - test print.
If this doesn't work then the problem is likely a paper setting (set to legal or something) Good luck.
on Aug 27, 2010 | Office Equipment & Supplies
Dell vostro 1710 won't start after bios update
Assuming you did the correct bios update, you may need to remove the CMOS battery for about 30 seconds and then replace it.
Jul 05, 2012 | Dell Vostro 1710 Laptop
Paper jam light is on
Look real close. It is difficult to see very small pieces of paper that coudl be lodged in many areas. Also if you take a clean cloth with a little rubbing alchol and clean the sensors, this may help
Jun 17, 2010 | Dell 1710 Laser Printer
My HP laserjet p3005dn has tray 2 filled with paper but troubleshooting says to load paper. I've checked the configuration settings and they are set to automatic so I can't figure out the problem.
Hi, You need to go into menu and check you tray and paper configuration, for instance if you have letter paper in tray 1, go into menu and scroll to paper tray 1 and make sure it says letter paper 81/2 x11, then do the same for tray 2. Even though the machine has the required size paper and set to auto, you have to go into menu and tell the machine what kind of papers are in the trays, the machine don`t do this automaticaly. Getting a Service Manual will help you further, you can get one here www.techmanualarchives.com
Mar 13, 2010 | HP LaserJet P3005n Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
My dell 1710 has a paper jam, but I cannot see it. How do I find it?
http://www.ehow.com/how_4929022_fix-paper-jams-dell.html
Oct 12, 2009 | Dell 1710 Laser Printer
Dell laserjet 1720dn
Reseat the paper in the paper tray, and replace the pickup rollers for both trays, note the pickup rollers are in the trays and under each tray.
Feb 12, 2009 | HP LaserJet 4250n Printer
DELL 1710- PAPER JAM AFTER EXITING PAPER BIN!
Preface; I am a support tech for a major gov't facility and we have hundreds of the Dell printers and PC's.
2 possible solutions. I have seen both. Items can get stuck in the paper path in the guide area, this is just before the pressure roller plate, this is the plastic piece under the fuser roller assy. The rounded plastic piece that guides the paper from the tray into the print area can have paper scraps or objects such as rubber bands, staples or paper clips caught inside of it. This can happen if any of these things get in the paper tray. I just pulled a rubber band out of one of these today.
Many times it is the paper sensor that is located under the pressure roller plate. After you remove the fuser asy you can see a plastic 'finger' that is just right of center in the pressure roller. There is another one a little further in and it is more center line on the 'floor' of the printer.
I have seen these go out with fair regularity. If you remove the paper tray and turn the printer on its side you can find the body of this sensor under the feed roller/arm asy that drops down into the tray to start the feed process. It has some white, plastice type material and wires running out of it. It is held in by a single screw. There is another sensor of the same design located by the pivot point for the feed arm. If the paper gets by the first sensor then stops, it is the second sensor that is out.
Oct 21, 2008 | Dell 1710 Laser Printer
Dell 1710 paper jam
Next time don't buy Dell. That's the solution.
Oct 05, 2008 | Dell 1710n Laser Printer
Dell 1710 Laser Printer Logo
469 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
