Question about Clarion DUZ385SAT Car CD/ MP3 Player
I have the Duz385sat stereo. the sirius does not work properly
I have the Duz385sat stereo. everything works great except the Sirius connect. when hooked up only one side of the speakers work in the vehicle. I changed out the black translator adapter and the cable to the clarion unit and that did not work, now I have to change out the Sirius SC-C1 tuner and cable. the store where I bough the unit back in June says it could be the Clarion unit itself. any Ideas? Anyone else have this problem? When I change the tuner and cable I hope this fixes the problem but I have a bad feeling it wont. any ideas would be good. Thanks!
Stuart Joynt
4 Suggested Answers
  • 166 Answers
SOURCE: clarion duz385sat wiring diagram
Here's what I found through Crutchfield's site:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/020/020DUZ385.PDF
That has the wiring diagrams right within the last 3-4 pages... go check that out.
Posted on May 05, 2010
pctech1
  • 1940 Answers
SOURCE: One of my customers has a CMD6 with SIR-CL3 Sirius
If you know the Sirius Tuner works, then this is a problem with the Clarion Head-Unit or the cable used to connect the 2 devices. If after replacing the cable it still doesn't work, then you must contact Clarion in order to resolve this issue with your CMD6.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Feb 10, 2011
I am having the exact same problem with my CMD6. The sirius worked fine with my CMD4, but has the same problem with constantly rebooting when I hook it up to the CMD6. Did you find a solution?
Posted on May 02, 2011
I have an onkyo 646 receiver and I added the Sirius xm radio and everything works and I have a good connection but no sound
Plug another device into the inputs that you are using for the sirius - if it works then the inputs are fine and there is an issue with your Sirius audio output.
Sep 19, 2017 | Onkyo Audio Players & Recorders
I just bought a new radio for my jeep and it says it is SiriusXM ready. Does this mean all I have to do is get a plan?
No this means you can control Sirius radio with your car stereo, but you still require A sirius external device. In other words your looking for simply a Sirius add-on Kit for your stereo, If the kit comes with controller, which most do, then the fact your new car stereo is Sirius Ready, makes the Sirius controller obsolete. I hope this helps.
Carlos Q
Apr 05, 2015 | Jeep Car Audio & Video
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
On a 08 RAM with factory Sirius, can it be
No it will not work... I have tried it
Sep 21, 2009 | 2008 Dodge Ram Pickup 1500
I have a JBL MR-17.2 Sirius Ready stereo
To get your Sirius ID number from you MR-17 JBL stereo, select the Mode button until it displays "Sirius". Then push and hold the Mode button for a couple seconds and it will chirp and display 3 blank spaces. Enter three zeros, "000" in these 3 spaces. The Zero is the loud button labeled "LD". When you do that, it will display your Sirius ID number. :)
May 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
Sportster 4
Shouldn't need one. Does the rear antenna connect to the direct FM box?
Aug 30, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Problem with memory
The problem is simple to fix...shut off radio replays. Thought they are supposed to make you aware of low memory..the replays seem to automatically replace "loved" songs.
May 31, 2008 | Sirius Stiletto 2 Portable Satellite Radio...
Connecting Sansa e260 to factory car stereo
there's hardwire kits (http://www.crutchfield.com/S-oVN2ByB3OJo/App/Product/Item/Main.aspx?g=234550&I=142FMMOD01&id=review) and tape deck adapters. sirius might work if only audio jack is needed
Apr 07, 2008 | SanDisk Sansa e260 MP3 Player
Clarion Marine XMD3 / SIR-CL1 Sirius Troubleshooting
I had the same problem with invalid channel on all channels ! Had to reset the siriuss receiver by removing power for 15 sec and restoring! that means not just shuting it off but removing all power to the sirius unit not the clarion unit itself and reastablishing power to it turning on the clarion head unit and walah! satelite would recieve ESN and 184 and programing! Hope it works for you after 3 long waiting periods on the phone!
Oct 21, 2007 | Clarion SIR-CL1 SIRIUS Radio Receiver
Clarion DUZ385SAT Car CD/ MP3 Player Logo
43 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
