Question about Canon PIXMA iP2000 InkJet Printer
Waste ink absorber
Pixma iP2000 Printer. I am getting an error message "Waste ink absorber is almost full. Press resume button to continue printing. Please help!
  • 1 more comment
  • kandbdavy Dec 23, 2007
    This worked for me and seems to work on all Canon printers.
    (1) Turn off the printer.
    (2) Press and hold the RESUME button, then press and hold the POWER button.
    (3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will “reset" or move momentarily.
    If the above was properly performed the printer will enter the "Service Mode".
    (4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. Next press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
  • Anonymous Mar 13, 2014
    ink absorber is full
  • Anonymous Mar 28, 2014
    Try to print get error that ink absorber is full. Says 'Press OK' to continue printing but that does nothing.
  • 52 Answers
Hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
Posted on Jan 05, 2008
Green light flashes 8 times
IF THIS IS A PIXMA IP2000, then
Eight flashes = Waste ink absorber* almost full. The printer has a built-in waste ink absorber to hold the ink consumed during Print
Head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the R R ESUME/CANCEL button to clear the error so printing can continue for a while.
A longer term RESET IS possible BUT without changing the blotters, you're exposed to ink eventually running out of the printer without warning but... if you still want to continue, here are the reset instructions. Good luck!
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The indicator will blink in green and remain lit in green.
Now press the resume button 4 times and then the power button. You've just reset the waste ink counter. Good luck. Just hope it doesn't come back to bite you!
Aug 31, 2014 | Canon Office Equipment & Supplies
Lights flashing 7 times
Never heard of 7 flasjhes.
Five flashes = No Print Head Installed. Install or re-install.
Aug 31, 2014 | Canon PIXMA iP2000 Photo Printer
Every time I try to print I get an error message as follows: Error Message 1700: Waste ink absorber is almost full. Press resume to restart. My manual says nothing about a "waste ink absorber" so...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Nov 18, 2010 | Canon PIXMA iP2000 InkJet Printer
My yelow light appears saying waste ink absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 25, 2009 | Canon PIXMA iP2000 InkJet Printer
Tank for used ink is full - how do I change it?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
My Cannon ip pixma 2000 is saying that the waste ink absorber is almost full how can i solve this
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Reset ip2000
1. Turn off printer
Oct 10, 2009 | Canon PIXMA iP2000 InkJet Printer
Ink waste absorber is full. Canon IP2000. How do I repair it?
Well, at some point you will need to either replace or wash the absorber pads in the printer - but you can reset the warning as follows:
1) Turn the printer off
2) Press and hold the <resume>button
3) Press and hold the <power> button
4) While holding down <power> release <resume>
5) With the power button still held down, press <resume> twice more
6) Release the power button
7) Press and release the <resume> button 4 times
8) Press and release the <power> button twice
At this point, the printer should come back online with the waste ink warning reset
Personally, I would only do this once before actually changing the ink absorber pad...
Aug 31, 2009 | Canon PIXMA iP2000 InkJet Printer
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
Waste ink tank full
You can try this
Reset ip2000
1. Turn off printer
Jan 21, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
584 people viewed this question
old marine
old marine
