Question about Frigidaire FEF352 Electric Kitchen Range
Electric shock when wiping oven-light switch
Yesterday, I got an electric shock in my arm when wiping the oven light switch with a damp cloth. Today, when I did the same thing a fuse went out in my house. The man who came to fix it simply dried the moisture and told me not to wipe the light switch again. What should be done to fix this problem?
    President:
  • 1,304 Answers
You may want to actually check you plug wire here
sounds like they wired neutral to the chassis ground
and vice versa
please check quickly
4wire connection
black left
red right
white center
geen on the chasis (cabinet)
3 wire
middle wire in the middle
the other two one on each side
then there should be a metal strip from middle to the chassis(cabinet)
Posted on Oct 05, 2009
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Tip
PC Tools- How to clean your computer
  • Cleaning the Computer
If you've noticed that your computer's keyboard feels sticky or the monitor screen appears spotted under the light, it's time to clean these pieces before internal damage occurs. Cleaning your computer's keyboard does not require special knowledge or skill. But you should take precautions to avoid damaging the internal parts when caring for the external hardware.mike_alozie_0.gif
1. Unplug the computer and all accessories before getting started. Anytime you attempt to clean an electric appliance it is important to disconnect the power source to reduce the risk of electrocution or shock. After unplugging the keyboard and monitor, along with any accessories that may be plugged in, use a damp clean cloth to wipe all the cords that are connected to the monitor and keyboard and remove dust balls or hair, along with anything else that might cling to them.
2. Move the computer monitor and keypad to one side of the desk and wipe the area clean where the equipment usually sits. Be sure to wipe a large parameter around the monitor area and let it air dry completely before returning the keypad to that area. You might want to use a clean towel or dry cloth to rub over the desk to be certain it is dry, as dampness can damage the machinery or cause it to stick to the table's surface.
3. Rinse the damp cloth in clear hot water and wring it nearly dry. Gently wipe the monitor screen, including all the corners, to remove dust and spots. Then wipe the surrounding areas and framework of the monitor, including the indicator lights that show when the system is operating. Don't forget the back of the monitor as well. If you have a laptop computer with a top that folds down and closes, wipe the hinges carefully, using a cotton swab for grooves and the latch. Check the latch to see if it is sticky or closes readily.
4. Next, go over the keyboard with the cloth, lightly rubbing around each key and button. Wipe around the sides of the keyboard, catching the off and on switch and CD player. Then use a cotton swab to ease around the edges of each key and row to retrieve minute amounts of dust and crumbs. Carefully clean around the lights, plug openings, and speakers, as well as other areas of your computer. Check to be sure you are not leaving wet traces on the equipment, as this means your cloth is too damp and should be wrung out more.
5. Allow the machinery to air dry, or use a soft cloth to pat the keyboard and monitor dry. Don't use fabric with lint or that is tough enough to scratch the screen. Reassemble all the cords and parts when you are sure the entire unit is clean and dry.
Plan to clean the keyboard and monitor every month or two. You may want to schedule maintenance for an interior cleaning once or twice a year. A clean computer is more likely to work well and last longer.
on Apr 25, 2011 | Computers & Internet
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
How do I clean my GE dual microwave and oven?
Yo! Get a liquid wash, spray a little on a damp, soft cloth and clean gentle.you can thereafter wipe the oven with a clean damp cloth. leave to dry off. take care.
Jul 20, 2011 | Kitchen Ranges
I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
hello,
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    How do I clean oven
    Hi
    These are the things you will need to clean your oven.
    Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    Jul 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How do i clean my westinghouse deep fryer cool touch wst3034
    Despose of the old oil. Hand wash everything with dawn dish soap and water. Except the electical componets wipe with damp cloth. Unplug for your own safety of electrical shock
    Sep 05, 2009 | Westinghouse WST3034 Deep Fryer
    I have a ge electric built in single oven which had a grease fire
    Its possible that the wiring harness to the door switch got a little too hot and have shorted. What I would do before I call a technician is to unplug the oven or turn the power off to it for a few minutes and then plug it back in to reset the control board. If you still get the error, I would recommend calling a service professional.
    Apr 03, 2009 | GE JTP20 Electric Single Oven
    How to clean a monitor screen
    Make sure the monitor is off. Spray a small amount of glass cleaner on a paper towel.
    Then wipe the dirt away.
    Thanks,
    Lee
    Jun 17, 2008 | Computers & Internet
    NEFF 7871 electrical problems
    neff built in microwave cannot open the door
    Mar 02, 2008 | Neff H7871 Convection/Microwave Oven
    Frigidaire FEF352 Electric Kitchen Range Logo
    320 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Paul Carew
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
