Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
Samsung le40 switch on power and it s clicking for about 20 mins then tv comes on
  • 304 Answers
SOURCE: Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Posted on Jul 16, 2009
freetek
  • 5568 Answers
SOURCE: T.V Problem
I think your main power supply is failing. If you want to avoid a long interruption or fix the problem now, read my stock response paste below:
If it's failing to turn on reliably, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Aug 13, 2009
  • 59 Answers
SOURCE: 42 inch samsung lcd tv tv takes forever to come on
I would check the power supply for bad caps they will have a swollen top replace those and that should fix your problem
Posted on Jan 28, 2010
SOURCE: samsung le40 tv switchs on and off standby on its
get rid of caption on t.v. screen
Posted on Jul 26, 2010
  • 33 Answers
SOURCE: Samsung 40" LED TV Display
Not familiar with this particular model of samsung LED TV, but ghosting and shadowing are usually an accepted manufacturer's defect.
If you're still under warranty or within 30 days of purchase, contact the company that sold you the TV or Samsung warranty department.
If you're out of warranty and you don't wish to deal with this, contact a TV repair shop. They will most likely tell you that it's not worth repairing and recommend you purchase a new TV.
Posted on Mar 11, 2011
Samsung dv3 tv LE40 76B
Bad capacitor somewhere, in the power supply area. Relay is ok.
Feb 13, 2014 | Televison & Video
Hi my Samsung plasma tv turns off randomly after 20 min ,1 hour ,5 min and sometimes you can tap tap just above the power input and it comes back on
my tv do the same thing, it's my power cord, check and see if it's
loose where it plugs into the tv, if yes that's ur problem if not don't know
Jan 16, 2013 | Televison & Video
I have a problem with the on off switch on my 40
Hi There
This is most definitely bad capacitors in the power supply, Take the back of and look for capacitors that are domed shaped on top,
Replace them with a higher voltage rating but the UF NEEDS TO BE THE SAME IE... 10V 1000UF CHANGE TO 35V 1000UF
This will cure your fault
Mar 05, 2010 | Televison & Video
Tv turn it off and turn it on every 20 min
put tv into standby and press INFO / MENU / MUTE / STANDBY on remote you have to be quick
the tv will come on with factory settings on screen
ONLY USE DOWN NAVIGATION KEY move to reset and press RIGHT NAVIGATION KEY press standby to exit
tv will come on and will need retune
if this not help then will be capactors on mains power board failing look at them and if any have raised tops replace then
Dec 15, 2009 | Samsung HP-T4264 42 in. Plasma HDTV
How can I get hold of a user manual for the samung LE40 R88BD lcd television?
http://origin.samsung.com/at/products/pvi/datasheets/flatpanellcdtv/r8/LE40R88BD.pdf
here yeah go
Sep 14, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Jul 08, 2009 | Televison & Video
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
473 people viewed this question
Henry  Thomas
Henry Thomas
