Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
DOOR BALANCE CABLE BROKEN
DOOR BALANCE CABLE BROKE HOW DO I RELACE IT
WHERE IS IT LOCATED
    President:
  • 1,304 Answers
There two
one on each side
to replace it
you need to slide the machine out of the cabinet
about half way
the cable starts at the bottom of the door down each side
Posted on Oct 05, 2009
Door doesn't open slowly, it drops down suddenly when opened. What is the problem please?
Pull the dishwasher out. You may see the mechanism and possibly broken spring or other part. (possible it's just come apart. You may need to remove side panels to see this mechanism for the door (counter balance) .
Apr 11, 2015 | Dishwashers
Why won't the drivers window go down but the other three windows do
Sounds like your motor is broken. I am assuming you are talking about electric windows. It could be the cables are broke or binding but if the cables were broke then usually the window would fall down to it's resting position.
Jun 17, 2014 | 1996 GMC Jimmy
I have a 96 toyota corolla and can't get the fuel door open
This is usually because the spring the pops it open is broken, have someone pry on the fuel door while ppulling the release inside, the spring clips onto the hinge if it's broken get a replacement from the toyota dealer
Jan 15, 2013 | 2003 Toyota Corolla
1997 toyota hilux broken bonnet release how to open bonnet
i assume you have tried pulling the cable including the outer insulator, then next step is from the front left corner of the bonnet!!:using a long 90 degree needle nose pliers,grab the black insulator and move towards the wing (important to only access here otherwise radiator/condensor can be damaged, if this fails then the end of cable BALL is broken! . access thru behind the grille FROM UNDER THE VEHICLE (locate the cable entry hole on the bracket, the release lever is onthe blind side of it ) good luck, tricky but a good pen flash light will be very useful. once open relace cable and TEST MECHANISM AND OPERATION without closing bonnet!
Apr 07, 2012 | Cars & Trucks
Hello, i just put a cup of coffee into the microwave and now the door latch does not allow it to open, any suggestions?
your going to have cold coffee . when you closed the door it prpbably broke the latch ear.. you may have to remove the shell and relace it from inside and the replac handle . ****
Jan 09, 2010 | Food Mixers
Door is broken
Hello Hickin! It would appear that one, or both of the door springs which act as a counter-balance for the weight of the door, have broke.
To confirm this and get at the spring(s), close and lock the wash compartment door and use a screwdriver (might be a 1/4" or 5/16" nut driver instead) to remove the lower panel.
Once you have the lower panel off, you should be able to see the door springs on each side. You'll probably also see part of the broken spring lying in there too. If the door spring broke near the end by the hook, it is possible to TEMPORARYILY bend the spring with a set of channel locks and pliers to form a new hook end, that you can attach to the door clip. If the spring is broke near the middle, you'll need to get a new one.
Regardless, you'll need to locate the model number for your dishwasher and obtain a replacement spring ASAP, as the temporary repair will only work for a short while before the spring breaks again.
You might want to try Fagor at their site to see what the part number for the replacement spring is. http://www.fagoramerica.com/
The other option with your model number is to try the Sears part web site, which shows a line drawing and parts list for most applianances.
http://www.searspartsdirect.com/partsdirect/index.action
This repair is relatively easy for anyone to undertake and you can save yourself the cost for a service tech's labor charges, plus the trip/house charge they normally tack on.
I hope you find this Very Helpful and best regards!
Oct 12, 2009 | Fagor Dishwashers
The spring on the door broke. How do we fix it?
get a spring from a kitchen aid parts supplier and relace it
Sep 28, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Could all this be an electrical problem?
open the drivers door look in the opening locate a black rubber tube then locate the driver kick panal located at door opening and floor remove the panal locate where the black tube comes through push tube out you will expose wires you will find one or more wires broken most all camrys does this as far as the trunk it sounds as though your cable poped off or broke hope this helps if you need more help please contact mo via E-MAIL @ royhyreno9@yahoo.com
Jan 15, 2009 | 1999 Toyota Camry
WHEN OPENING THE DISHWASHER DOOR, IT DROPS QUICKLY.
Actually I found out that for a LG dishwasher it is as likely to be the cable/cord attached to the spring and door. This a very odd setup in that this cable is made of nylon cord, and not any thicker than a round shoelace! It clearly should be metal cable, and it's not that hard to replace the nylon stuff with steel. Anyway, it is worth it to pull the unit out and open the side panel to see if in facts it's a broken cord or spring first before ordering any parts.
Dec 04, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
162 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
