Question about Samsung SGH-d807 Cellular Phone
Samsung-D807 Headset/Power Connector Crooked
So I was about to charge my Samsung D807, but after I connected the adapter, nothing happened. I tried connecting the headset, which I never even use with the phone anyway, but it was loose with the Headset/Power Connector. I looked through the little slot and saw that the Connector's gone crooked inside the phone.
This is weird because I charged the phone a few days ago and nothing was messed up, and I didn't drop the phone.
So is there anyway I can adjust the the Connector back to being straight? I've only had this phone since July.
  • chelsea420 Jan 04, 2008
    exact same thing happened to me, the little metal thing in there is like pushed back. i dont know what to do...
  • shshasharon Jan 06, 2008
    i've had this phone for almost 2 years now. and for the past 3 months it's been giving me charging problems. at first i thought it was my charger and got a new one, but in 2 weeks the second charger gave me the same problem. I'd plug it in and it does not charge.. what do i do!!?!?
  • 68 Answers
It is a common problem on this model. This connector is fragil and prone to breaking.
To continue to use the phone without sending in for repair purchase an external battery charger.
I'm not endorsing it but if you don't know where to purchase it, try this site:
Posted on Jan 11, 2008
My samsung E251 is not charging. Battery indicator just keep on blinking but not work for charging
this also happened on my samsung i5810. when i send for customer service what they did it that they shocked my battery (connected it to a dc power supply) and it worked afterwards. but there could be also other scenario that would caused this like loose charger connector (try to reseat the adapter) or the battery is already washed up.
Oct 07, 2009 | Lands Phones
I tried to switch on my laptop and it started booting and suddenly went off.From then on its not even booting.Nor does it show the green light which comes on, when you plug it to a power source. Its...
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
A faulty adapter or the connector is not making proper electrical contact, this causes the LED not to illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
May 09, 2009 | Lenovo R61 T7300 Notebook
Samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
Hi there!
OK I know it is little late to response but if someone will google it, might find the solution, they are still selling it though. I just got my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small power in it, however you have to charge it. So connect the small charging cable into the base unit and the headset and make sure the switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity supply. Connect the audio connector from the base to the e.g. TV, PC, DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have two of the same wireless sets. So if on the base is set to # 1 the headset needs to be also on # 1. Then if you have second headset choose channel # 2 on the base and also on the headset # 2, so they are not crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
Hope it was helpful.
Michal Bohucky
Jun 01, 2008 | Audio Players & Recorders
Samsung d807
plug in a headset remove it and then switch the phone off.that should work i had the same problem but with a diffrent phone.
Dec 27, 2007 | Nokia 1100
Charging port connector
You can get it fixed at a place in Los Angeles Tel: 323-651-5555
Nov 18, 2007 | Samsung SGH-d807 Cellular Phone
Same thing happened to me with this phone and a brand new one (same model). I suggest getting a different phone.
Sep 19, 2007 | Samsung SGH-d807 Cellular Phone
Samsung wp170
Try changing the battery.
Aug 24, 2007 | Samsung WEP170 Wireless Headset
Motorola HS850 and samsung d807
I tried Paring my motorola 8s850 for a second time and it tells me my passcode is incorrect...Can't Figure this out at all
Dec 11, 2006 | Motorola Mobility HS850 Consumer Headset
Samsung SGH-d807 Cellular Phone Logo
56 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
