Question about Acer Aspire 1640Z Notebook
How to install windows on a new hard disk - Acer Aspire 1640Z Notebook
    President:
  • 1,566 Answers
Hi!
You need to have the Windows Installation disc and also the license to be able to install a new copy of Windows.
First step is to boot into the CD/DVD. Set the boot priority of your computer to the CD/DVD drive via the BIOS utility. You usually hit F5 once the computer boots up. And then Boot Device Priority. Press Esc and then save the settings.
After you are able to boot in the CD, follow the screen prompts until you go into the partition screen. I would advise that if you only have one hard disk, partition it into two. One is for the system and another is for the data. This is to make sure that even if your windows crash, you can still retrieve your files saved under the second partition. Finalize the installation, wait for the process to continue and then reboot.
Take note that you need to run Windows Update after the installation. This is to ensure that your version is fully patched. Do not forget to install an anti-virus too for enhanced computer protection.
Posted on Oct 05, 2009
    Genius:
  • 1,341 Answers
Check if bios is set to boot from cd, put the cd in the pc and restart it then follow the screen instructios..
I want to format my c drive with the help of Dos command prompt , installed win 7 ultimate.
Formatting hard drive When booting from a Windows installation CD select the option to install Windows then you (can either delete the existing partition/s then create a new partition then you) can format the hard disk. After formatting the hard disk you can abort the Windows installation if you do not want proceed to install Windows.
You should be able to use the Windows 7 installation CD to delete the existing partition, create a new partition and format the new partition and then install Windows 7.
Apr 03, 2013 | Computers & Internet
What drivers are need for clean windows xp install on sony vaio pcg-k37?
This model Sony came installed with a 80Gb hard disk and a 40 Gb
Do a clean Windows install on this old hard drive -
Boot up with the Windows installation CD
install Windows on the hard drive
Delete the existing Windows partition
Create a new partition
Format the new partition (full format not Quick format)
Continue installing Windows.
Mar 24, 2012 | Sony PCGK37 Notebook
New hard drive operating system not found
The reason why you cannot install Windows on your hard drive is this model Sony has a SATA disk controller.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 17, 2012 | Sony VAIO VPCEA36FX PC Notebook
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
I CAN'T INSTALL A WINDOWS XP SOFTWARE
Thank you for choosing Fixya.com
Yes you can install the Windows XP on P4X266.
Here could be five various steps you can go about.
  • Method 1: Perform a clean install of Windows XP
    Use this method for a clean installation of Windows XP. A clean installation removes all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk.
  • Method 2: Upgrade to Windows XP
    Use this method if you are upgrading to Windows XP from Microsoft Windows 98, Microsoft Windows Millennium Edition, or Microsoft Windows 2000 Professional.
  • Method 3: Install Windows XP to a new hard disk
    Use this method to install Windows XP to a new hard disk. This is typically done when a new hard disk is installed on your computer.
  • Method 4: Install Windows XP to a new folder (parallel installation)
    Use this method to install Windows XP to a new folder (parallel installation) to either run two operating systems, or to access, repair, or retrieve data from a damaged disk.
  • Method 5: Perform a multiple boot operation
    Use this method to install Windows XP as a separate operating system on your computer. This lets you install more than one operating system on your computer and select which operating system that you want to use every time that you start your computer.
To check the detailed information, check this Microsoft Knowledge Base Article.
http://support.microsoft.com/kb/316941
Hope this would help !!
Regard's
Anurag Shukla
Sep 08, 2009 | VIA P4X266 PE11-L Motherboard
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
I installed a new hard drive in a Gateway 4XL.
See your hard disk Jumper setting it could be wrong change jumper of your hard disk then install the windows.
Mar 07, 2009 | Gateway Profile 4 XLb PC Desktop
New Hard drive xp install
If your hard drive is SATA and your windows disk does not have SATA drivers on it it will not find the hard drive this is your problem
http://driverpacks.net/DriverPacks/
Go to the above site and download "driverpack mass storage" and slipstream into your windows CD.
I have done this with one windows install disk that could not find disk then it worked perfectly
Nov 05, 2008 | Abit KT7-RAID Motherboard
Hard drive
You need to use a Windows install disk, or the computer recovery disk.
At startup of new windows installation, chose new installation and then chose the option Format hard drive.
Note: the windows install disk must be bootable, Upgrade install disk (non bootable) does not have the format option.
Regards
Nov 05, 2008 | Toshiba Satellite A135-S4527 Notebook
New hard drive to install windows sayind
If you have not checked these(I am sure you have probably gone through this or don't need to but just in case)
First thing is first you have installed a new hard disk, is this the only hard disk installed. If Yes, does the bios recognize it? If Yes, is it bootable. Meaning is there a working copy of windows installed? If not reinstall from windows installation disk. If Yes, you may still have to reinstall windows you can use the windows installation disk as well.
This sounds like an issue that I had taking a hard drive from one computer and placing it in a brand new one. This message sounds like windows is damaged. I had to reinstall windows and leave the file system intact. There is an option to do this. If you feel comfortable you can always use a boot disk and check the boot .ini to make sure that it has the correct path for windows written in that may be the issue there. This file is hidden in the root directory of the drive.
Nov 30, 2007 | Computers & Internet
Acer Aspire 1640Z Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
