Question about Philips Health & Beauty
Sonicare - Just a single buzz and dies
This problem was happening with the old batteries, got them replaced and put in new nimh batteries, it worked once beautifully and then thereafter, when i press the start button, gives a single buzz and dies..... I have tried to charge with the brush attached with it and all sort of combinations. No luck yet.
If anybody finds a solution, please let me know. I am not in the US now and cannot afford to buy a new one in asia.
Thanks
SOURCE: dvd tray is locked and i cant find the manual to unlock it.
Press the open button down for 5 sec and the dvd player will say unlock and then you can hit the open button and the tray will open. I just did this. IT WORKED YEAH!!!!
Posted on Feb 25, 2008
rytech uk
  • 85 Answers
SOURCE: Back up battery
It sounds like (in all 3 cases) a new backup battery is required.while these are cheap to obtain, they are not always that easy to replace. I can provide detial on how to change them if required.
email techservices@rytech-uk.co.uk, and i'll send a picture guide to you.
**Rytech cannot be responsible for damage caused to your ipaq by follow any of our self help guides. If in doubt, contact a authorised HP engineer**
Posted on Jun 20, 2008
upajos
  • 24 Answers
SOURCE: please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Posted on Oct 29, 2008
SOURCE: Batteries "depleted"
Ok.  So far this has worked for me.  I had exactly the same problem and called Canon service after reading your post.
This is what they said to do, even though it sounds a little hocus-pocus:
• take out the batteries & camera card • clean the battery contacts ON THE CAMERA (those bumpy little things) with an eraser • click the camera on/off button 10 x • click the "take photo" button 10 times • put in newly charged batteries.
Hint:  Remove batteries every night. Never leave batteries in for more than 24 hours.
So this has now worked for 20 minutes!  There's hope!
Valerie
Posted on Feb 19, 2009
SOURCE: Change the batteries message even with new NIMH RShack batteries
The solution is to change the small 'date/time' battery. You can have the regular batteries as charged as you like, it won't make any difference. The tiny date/time battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open).
Posted on Oct 25, 2009
Testimonial: "I don't even knew about the this date-time battery. I will buy a new one and replace it. I am pretty sure this will solve my problem. Thanks"
My sonicare shuts off prior to the two minutes of brushing even though it's fully charged. It's only a year old.
If it stops working, the battery has failed. They are replaceable, but you need to know how to desolder and solder.
Philips Sonicare FlexCare Battery Replacement
Apr 22, 2018 | Sonicare Health & Beauty
My shaver turn off immediately after it turn on
How old is the shaver? What model is it? How handy are you? It is possible the battery is dead. As with most electric shavers they try to tell us the battery is not replaceable, but if we take it apart the battery has either a model number or specifications on the side we can hunt down and purchase.
Even if you can't find the exact same model, make sure the specs are the same as the ones on the original battery and it's the same size roughly. Then it's only a matter of re-connecting the new battery in place of the old and away you go.
Popular sources for unconventional internal battery replacement is places like eBay, or if you want local, try an electronics store. If you can't find the exact battery as a replacement, you can use any as long as the chemistry, and battery specifications are the same you shouldn't have a problem.
My portable hand crank radio (for camping and power outages) had an internal NiMh battery pack which died after a few years of lack of use. Buying a new one from the manufacturer was a ridiculous price. Simply matching the specs and size I found a similar battery for a wireless home phone and used it instead. It works great and it cost a lot less than buying original.
My cordless Shark 14.4v hand vac rechargeable battery died, and there was no replacement battery. Taking it apart I discovered how the 14.4v internal battery was composed of. Several (12) 1.2v cells linked in series. So I simply bought 1.2v cells and linked them myself and put them back into the hand vac. Works great now.
Aug 30, 2015 | Health & Beauty
Which AA battery shall I buy for my digital camera? 1500? 1000? 2500?
Although you could use these, do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights. The lower capacities suggest NiCd batterie. Also don't use these.
A set of new NiMH batteries, from 2000 to 2600 mAh with a good charger, will be fine.
Two things.
There are very fast chargers around. Don't invest in them. I payed 80 euro for a quick charger. Could charge 2700 mAh batteries in 15 minutes. The charger killed all my NiMH batteries I had (more than 40) It took me till the fifth or so died, before I realised it could be the charger. Since I stopped all my batteries one by one died and I had to replace them all
I now have some "fast" chargers that take 2 to 3 hours and the new batteries Can handle that.
Better buy a slower charger and some good batteries, than the other way around.
Second. Test the 2600 mAh batteries, if they fit.
To put more capacity in the "same" AA battery some brands made them slightly thicker. So it could be you can't get the largest ones in your camera.
Mar 21, 2015 | Cameras
My sonicare toothbrush starting beeping during the night and kept beeping.
Probably two reasons for this. 1) the contacts at the base of the brush are not clean which will prevent proper charging , the low battery beep is telling you to recharge.2) the battery needs replacing.
Sep 23, 2014 | Sonicare Philips Flexcare+ with UV...
The 4775 unit seems to take a charge but it does not run? It's making a light buzzing sound? I've opened the unit, checked the batteries and they seem fine?
If the unit is more than a year old, the batteries may well be dead...you would need a tester to measure the charge in the batteries. It's cheap to change them.
The shaver is easy to open:
http://johnfixesstuff.blogspot.ca/2013/02/how-to-replace-batteries-in-braun-4775.html
I used 2 garden variety Eveready 2450 mAh NiMH rechargeables from Super Store...NiMH because I had them on hand.
They're a tad short, so I inserted some folded aluminum paper on the Negative ends to take up the slack...done.
The batteries fit solidly in place.
Shaver worked immediately, and is behaving normally while plugged in to recharge (green LED steadily lit as it should be).
We'll see how the NiMH batteries do in the NiCad charger. I can always replace these batteries with NiCad's.
Feb 03, 2013 | Braun 4775 Electric Shaver
Whenever I put new batteries into my Canon Powershot A480, I get the same thing - I get the 'Low Battery' red flashing light. And Then as I go to take a picture it shuts off and says ; Change The Batties....
I've got the same problem with 2 A 480 canon. I put in NiMH batteries and they work fine. If you put in slightly drained used batteries they work!! Nimh batteries are 1.2 volts and Alkaline are 1.5 volts. There is definitly a problem with this camera. I measured the voltages of brand new batteries 1.51 volts each and they didn't work. I put in some old batteries 1.4 and 1.42 volts and they worked fine.
Dec 17, 2010 | Canon PowerShot A480 Digital Camera
My camera will not charge or turn on
Without more information I'd head straight for the batteries. Some cheap rechargeable batteries don't last long and if they are old they could get to the stage of dying. Something nimh Batteries do well is die very quickly. if they are reasonably new it's possible for just one cell to die which would stop current from flowing from the others. Try a new set of high drain alkaline camera batteries and try them. if all works normally then buy a couple of sets of rechargeables. Make sure they are good quality, not cheap and nasty.
Apr 10, 2010 | Kodak Easyshare M753 Digital Camera
Bass speaker buzzing
I've had this problem too multiple times. Usually when it happens, the battery dies soon after, and once I replace the battery, the buzzing goes away. If you are having the same problem as me, try putting a fresh battery in :)
Mar 09, 2010 | Skull Candy Skullcrushers Headset
Camera immediate shuts off after turning it on
try using lithium or nimh rechargeable batteries. I had the same problem and switched out the batteries and put in eveready nimh batteries and it works fine now. Guess the old cheap ones weren't doing the job. And they were brand new batteries.
Oct 12, 2008 | Nikon Coolpix L11 Digital Camera
Health & Beauty Logo
170 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
