Question about DeLonghi Kitchen Ranges
Cooker delonghi professional dfs903 6 ring hob has terible fan like noise whenever you turn the oven on which has now become unbearable and occurs whether using the grill, the oven on fan setting or not. it occurs as soon as you turn the power on. It is so deafening ! Equally the oven door does not shut closed anymore perhaps due to weak return springs on the doors ? Can you help?
I had the same problem, the noise is coming from a circular fan located under the hob itself. not from the fan at the back of the oven.its a cooling fan.i bought a new one online around £70 and got a local gas fitter to install it. its a real big job and most if not all of the gas connections to the hob have to be disconnected its a big job.but worth it.
i have the same problem with the door,thats what im looking for.
if i find a solution ill let you know
Posted on Aug 11, 2010
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Have installed Delonghi undercounter stainless steel oven and hob bought from local supermarket. Fan making terrible noise like its touching something. My daughter has same oven and has exactly the same...
Do not disconnevt fan under any circumstances, otherwise it will cause big prob, if it is new, I would take it back, if it is under 28 days old, then they are legally bound to change it` for a new one., if more than 28 days old, then get them to repair it under guarantee.
Please rate my solution.
Thanks.
Aug 24, 2009 | DeLonghi AS670 Electric Single Oven
Fan oven door, cooker surround and hob become burining hot when using fan oven
Sounds like a problem to me. Check your oven door gasket to make sure it's intact and also that the oven door is closing completely when this overheating occurs. Although some heat will rise, it shouldn't become "burning hot".
Mar 09, 2008 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
Kitchen Ranges Logo
732 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Sal DeAngelo
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
