Question about Logitech Attack 3 Joystick
X AXIS INSTABILITY
THE CROSSHAIRS MOVE RIGHT ALONG THE X AXIS AFTER CALIBRATION CAUSING A PLANE IN FLIGHT SIMULATOR X TO BANK UNCONTROLLABLY TO THE RIGHT. tHE CROSSHAIRS ALSO MOVE IRRATICALLY WHEN THE STICK IS MOVED HORIZONTALLY. THIS APPEARS TO BE A COMMON PROBLEM BASED ON WHAT OTHER USERS HAVE SAID.
  • 2 more comments
  • Anonymous Jun 08, 2008
    Logitech Extreme 3D Pro frequently fails to calibrate in the X axis. Removed Logitech drivers and joystick functioned for about a week using Windows drivers. Joystick often fails to caibrate on any PC. 'Calibrated' position in the X axis is random. Tried uninstalling and reinstalling Logitech drivers and also ran the calibration clearing utility from Logitech. No effect on the X Axis stabilt seen. On stripping the joystick, no loose wires or obvious defects seen
  • Alfred Dec 24, 2008
    We have the EXACT same problem. I've had this Attack 2 for some years. I soon stopped using it because it was so erratic, and blamed Windows. Now I find on 2 Macs plus a new PC that the joystick starts out full-range, then mysteriously the right excursion (digital code) decreases to almost nothing. e.g., 164 instead of 255. Sometimes erratic spikes to full-right are seen.
    I can't find a data sheet on the CP5766AM to try to understand the problem. I am an engineer but can't work without data. Is there a fix? Can anyone send me a datasheet? Thank you.
    ...N6AC ...missing Flight Simulator ...
  • Alfred Feb 18, 2009
    Guess what? Logitech support has sent me a replacement joystick!
    Finally a joystick that works! ...Al n6acATarrlDOTnet
  • pieterpret Mar 13, 2009
    the crosshare moves half way to the right each time i plug my joystick in i tryid the same thing other and other and still the same thing. im considering off throwing it in the bin and getting me a different joystick
It is unfixable and it boils down to bad desighn and cheap parts
Posted on Nov 18, 2008
The Problem with the Logitech Attack 3 Joystick is Unfix-able I Have even gone as far to take it apart and I Noticed a serious design flaw. The cable that runs from the main board of the joystick to the top of the stick that works the four buttons and trigger enters At the right side of the plastic motion boarders at the X-Axis side then the cable enters the shaft right through the upper side of the plastic motion boarder ware the X-Axis motion sensor is located so the wire blocks the full motion of the Attack 3 joystick on the right side.
I have moved the cable so it enters the center shaft of the stick above the pivoting motion boarder through a small hole that I cut out that's above the X & Y Axis motion Boarder.
the stick somewhat works better I get full motion to the right but it still moves erratically and it only moves erratically when moved to the right but like I said at least I get full motion on the right and I didn’t before I modified it.
the only thing I can say about this piece of **** is that Logitech made Two Major Design Flaws one is the construction of the Attack 3 and the other is the parts they chose to use in the attack 3 The parts are Just Cheap and there Build Team Needs to Stop Taking Short Cuts in Development and start to thoroughly test there Product before marketing. Just think how many millions they made from this one model and Logitech loves every sale.
Wish I had Pictures to show
Posted on Nov 17, 2008
    Problem Solver:
  • 4 Answers
Http://www.everythingusb.com/hardware/index/Logitech_Attack_3_Joystick.htm
http://www.everythingusb.com/hardware/index/Logitech_Extreme_3D_Pro.htm
See the links above, and you can find countless postings across the Net from users who are all experiencing exactly the same problems.
I am a keen player of Fighter Ace. I wanted a reasonably priced reliable stick, so I went for a manufacturer I knew well and considered I could be confident with .....
How wrong could I be? It basically doesn't work. I'm 25 years in IT and I've tried everything. I'm sticking it in the bin before I waste anymore time with it.
I'm just hoping the Saitek I have ordered will be a lot lot better!
My advice, bin it and never trust Logitech again.
Jenny
Posted on Aug 08, 2008
    President:
  • 2,712 Answers
Is this an issue only with this game or other games as well?
Here are some articles from the logitech website that may be of some help...
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=289
and
std_adp.php?p_faqid=27
Posted on Apr 17, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
Having trouble programing my extreme 3d pro joystick and FSX deluxe. I am using Vista. I can't get the elevator trim up/down to work. Doesn't even seam to work when i press 7 or 1 on the...
I would first of recommend doing a calibration of your joystick. To do that, make sure your joystick is connected to your computer and go to your start menu>>devices and printers. Once your window pops up, find your joystick and right click on the icon, and go to settings. You can find the calibration wizard there. Once that is done, open up your Flight Simulator X, and go to the settings tab. Along the right hand side, click on controls. From there you can configure your joystick buttons to whichever action you like. Please keep in mind as well when your are adjusting the elevator trim, rudder trim, that the adjustments made from one keystroke, or button push, are very very small adjustments. You can change that by moving the slider on the Repeat column, thereby making one keystroke or button push equal to multiple taps!
Sep 13, 2011 | Microsoft Flight Simulator X
Just purchased saitek yolk with throtle but its not working ,.tried calibration still does not work
I had a friend with exactly same issues, only he used a CH Flight Yoke system.
Calibration can be very tricky sometimes, and it has very often to do with how the configuration file has been set up.
You might have to rebuild your configuration file for your Flight Simulator before it will work properly.
However here is some hints for calibration fix from Saiteks UK support.
Maybe this can solve your problem, understanding how to make a valid configuration file for Flight Simulator.
http://www.saitek.com/uk/supp/yokefsx3.html
Good luck
Aug 24, 2011 | Saitek Pro Flight Yoke System Flight...
Speed doesn't work
no the buttons does not have anything to do with this, first you need to recailibrate the flight yoke. then go back into flight simulator and check the senitivity levels move them all the way to the right the null needs to be to the left let me know if this takes care the problem if not we can do some more testing.
May 08, 2010 | Saitek Pro Flight Yoke System Flight...
Speed doesn't work
The markings on the TQ are not to be used literally. I suggest you use it to get the speed you want on your gauge and ignore markings on the TQ iteslf. Try re-calibrating in your sim program so it knows what the full range of the throttle is.
Apr 26, 2010 | Saitek Pro Flight Yoke System Flight...
On call of duty my right anolgue stick when i go up it looks down when i go down it looks up
Jun 18, 2009 | Microsoft Xbox 360 Controller
When the yoke is pushed/pulled (the y axis of the yoke affecting the elevators of the plane) it also affects the x axis of the yoke or the ailerons of the airplane. In my case I want to gain height (pull...
although this did not solve my problem, it is worth a try to reset the calibration settings stored in the windows registry.
These are the steps for it:
To recalibrate, first unplug the controller.
Go to start/run and type 'regedit'
The registry editor will have a list of folders on the left hand side. Go
down into the following folders in order.
HKEY_LOCAL_MACHINE (HKEY_CURRENT_USER if on VISTA)
System
CurrentControlSet
Control
Media Properties
Private Properties
Direct Input
Inside the Direct Input folder, delete any folder that begins VID_06A3.
Once done, close the editor.
Plug the controller back in and move all the
axes (including throttle) through their full range of movement 4 times.
Now go to control panel/game controllers/properties to see if there are any changes to the test screen?
If it helps you, it didn't do it for me ;) but I reckon it's worth a try
Jun 11, 2009 | Saitek Pro Flight Yoke System Flight...
Where can i find more planes for esky flight simulator
Go to YAHOO! and search "add-on aircraft for esky ch4 flight simulator. GOOD LUCK!
May 17, 2009 | E Sky Flight Simulator Training Kit
When I bank right or left with joystick the screen Freezes
To check the joystick isn't the problem, go into control panel game controls, then check that the joystick appears and you can move the cross-hair around on screen, most modern joysticks are
auto-calibrating, but you could try running the calibration.
To check the game isn't a problem, unplug the joystick, then use the arrow keys to fly the plane, if it doesn't crash when you bank then it isn't the game.
I assume the game is Combat Flight Simulator 3, as very old games that were written for Windows 95,98,ME series often won't run on Windows NT,2000,XP,Vista as they are completely different versions of Windows. If this is actually Flight Simulator 3, you may need to consider buying a later version of Flight Simulator (FSX is the latest version, but may not run on your laptop).
Other things to try are updating the graphics card driver.
Norton shouldn't need deactivating, although it could cause problems if you're playing online.
Also remember that laptop graphics cards are never as powerful as desktop graphics, and games very rarely specifically support laptop graphics.
Hope this helps.
Jan 21, 2009 | Logitech Extreme 3D Pro Joystick
Logitech Attack 3 Joystick Logo
723 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
