Question about Brother MFC-290C Printer
Printer is showing cannot detect black ink reinstall slowly
    Guru:
  • 355 Answers
Unplug cartriage and then try again
Posted on Oct 05, 2009
  • Albert Grupe
    Albert Grupe Jan 21, 2014
    no. unplugged several times and slowly reinstalled but still same problem
    New Friend:
Need to have someone take a look at it. can you do home service in Quezon City?
Posted on Jan 21, 2014
2 Suggested Answers
komguy
  • 2306 Answers
SOURCE: My Brother MFC-290C printer is displaying
With the full ink installed you might try plugging in power while you hold the stop key, sometimes the error is just locked and not cleared until you power up this way.
Posted on Oct 13, 2009
Cannot detect black ink reinstall slowly
your developer is weak or check tonar detective sensor
Mar 24, 2014 | Toshiba e-Studio 232 Black and White...
Would like to inquire if you do home service in Quezon City
Pull out all cartridges and take a flash light, look inside the printer, in the upper-back part you'll see black pins, check if are they clean and embedded, if black pin in even a bit loose, you'r need to solder a new pin on the PCB
Jan 21, 2014 | Brother DCP 165C Compact Color Inkjet...
Cartridge in but printer saids cannot detect reinstall slowly
I've just resolved this problem on one of these printers. There could be more than one cause - but this is worth checking. The cartridges for this machine are just ink reservoirs - there are no electrical connections to the cartridge. This is written based on my experience with the black cartridge, the sensors are repeated for each of the other cartridges so my notes should apply to all. This particular printer had been using non-Brother ink for a while - this may or may not be the cause of the problem.
If you remove the black cartridge and look into the area where it came from you can see 2 black plastic arms extending horizontally out of the middle of the slot at the back. One of these contains a infra red transmitter, the other an infra red receiver. The printer knows if there is something blocking the beam between these 2 arms or not.
The cartridge has a plastic bar on it which will break the beam as it is inserted. When the cartridge is fully inserted the beam looks through a transparent window in the cartridge, so the beam is broken if there is ink. If the cartridge is empty then the beam is not broken.
The plastic bar which initially breaks the beam is quite small. If you insert the cartridge too fast then the beam will be broken for a very short period of time - the printer may not have time to detect this.
There is also another pair of arms with infra red transmitter/receiver above the back of the cartridge which detects when it is inserted. As the printer knew the cartridge was fitted (it would otherwise display a "no cartridge fitted" alert) I knew this sensor was ok.
In my situation the black ink had gummed up one side of the black arms which I originally described. This meant that the beam was always broken. The printer cannot understand this situation as it expects the beam to be intact before the cartridge is installed, then broken as the black plastic bar passes through it, then intact once the bar has passed, then broken by the full ink cartridge. If this sequence is not seen then the printer displays an error.
To fix this - try cleaning the inside face of the arms. The transmitter/receiver are in a slightly indented area about 2mm square. I suggest IPA (Isopropyl alcohol/rubbing alcohol) on the end of a cotton bud.
In my case the ink was too heavily gummed, so I dismantled the printer, removed the circuit board behind the cartridges containing the sensors for the 4 cartridges and continued cleaning using a pin to carefully scratch the dried ink off. Take care not to scratch through the plastic window over the transmitter/receiver. Note, the control panel and the entire upper section of the printer needs to be removed in order to reach the back of the cartridge bay.
Please take proper precautions if you need to dismantle the printer. It contains delicate mechanical and electronic parts, and obviously has mains power entering. I take no responsibility for your safety or the continued operation of the printer. If in doubt, take to someone who can repair it and provide this information to help with their troubleshooting.
Once the printer was reassembled, I powered it up and slowly inserted the black cartridge, at which point it went through the usual process of asking if it had been changed, before showing the 4 inks as being full.
Darren - ex-electronics repair engineer
Apr 12, 2012 | Brother MFC-5890CN All-In-One InkJet...
It alwayas says on a printer screen "reinstall slowly cannot detect black ink" please help!
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Apr 25, 2011 | Brother DCP 165C Compact Color Inkjet...
DCP j125 Inkjet printer stopped printing showing msg. ink absorber is full. What to do?
well, cut the small piece of black tape (or you can use black permanent marker) and then cover the sensor of the cartridge, once the device will ask you to reinstall the cartridge and new system will detect as a new cartridge
Mar 30, 2011 | Brother DCP117 All-In-One InkJet Printer
Black ink cannot detect reinstall slowly
HI Good day!! Remove all your ink cartdrige and insert it 1 at the time slowly.. I think your using brother printer.
if not work please reply i will assist you more..
REGARDS
JR
Oct 18, 2010 | Office Equipment & Supplies
I just installed ink and now my computer is telling me I can only print in black because Cyan, Yellow and Magenta are empty, however they are full. I can hear the ink sloshing around and the printer...
While you reinstalled the ink the procedure did not allow the software to detect the difference.'hence I would suggest that the printer be removed and uninstalled,
Use tthe Cd provided to reinstall the software into the printer , Now plug back the printer and the new harware will be detected.
The ink will show correct and the computer to printer communication must be establised.
The test print must prove this out.
Credit if the advice helps.
Aug 26, 2010 | HP Photosmart C5180 All-In-One InkJet...
Black not printing
My refill my printer ink (i remove it) but still the screen appear to ask me "cannot detect black ink, reinstall slowly"
Apr 05, 2010 | Brother DCP 165C Compact Color Inkjet...
My Brother MFC-290C printer is displaying "cannot detect black ink" on the screen. I tried to re-install slowly and it is still not detecting the ink.
Oct 13, 2009 | Brother MFC-290C Printer
Ink level status on black ink is not accurate
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-290C Printer Logo
593 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
