Question about Canon PIXMA MP600 all-In-One InkJet Printer
HAVE JUST INSTALLED PRINTER IT WILL NOT EVEN COPY COPY CORRECTLY ALL OUT OF ALIGNMENT
  • 330 Answers
Check the document page alignment and see the print preview before print
Posted on Oct 05, 2009
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
I was given an HP Officejet J3640. I installed the HP21/22 ink cartridges, printed the alignment page, then loaded the alignment sheet in the feeder. After I loaded the alignment sheet, it responds...
Hi
Check if the alignment page has been printed correctly i mean the bars printed with a little yellow color around it right?
Okay what you can do is do a reset first. Follow the below things
1. When the printer is on remove the power directly from the back of the printer.
2. hold # and 9 key and connect the power
3. Printer will show you on the screen it is resetting the NVRAM then release the buttons
The printer will print alignment page again this time try to scan and it should work.
DO RATE MY SOLUTION
Jun 30, 2011 | Office Equipment & Supplies
Colored lines on a copy page
To fix the colored lines on a copy page do the below steps
  1. Disconnect the power cord, wait five seconds, and then plug it back in. This will reinitialize the unit and force the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the unit must be serviced.
  4. Verify that the alignment page is placed on the scanner glass or in the automatic document feeder (if equipped) correctly. Place the printed side down.
  5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
Dec 10, 2010 | HP OfficeJet k60 All-In-One InkJet Printer
Printer produces a poor copy
remove cartridges , take a q-tip w/alcohol and clean out ink ports where they drop ink onto the paprer the ports could be clogged with dry ink , thus preventing the new ink from reaching the paper. after you clean out the ink ports re-install the cartridges, and do alignment proceedures again this time color should be restored
Jul 11, 2009 | Lexmark X2250 All-In-One InkJet Printer
Will not align
depends ur able to copy or not if you r able to copy then uninstall and then reinstall the drivers if not coping then hardware issue .....................and for more technician support contact http://tinyurl.com/mtgjzz
Jun 22, 2009 | Dell 926 All-In-One InkJet Printer
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Problems priniting
copy alignment..did you try a test page`?
Oct 13, 2008 | Lexmark X3470 All-In-One InkJet Printer
HP psc 2110 Printer keeps telling me to Align print cartridges. I follow the steps but it always comes up alignment failed and starts printing Instruction page all over again. I can print from my computer...
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
May 18, 2008 | HP Office Equipment & Supplies
Printer will not copy
It Does keep asking if it fails to get it right, usually it fails to get scan of alignment page completed correctly because it fails to see one of the colours printed on its alignment page correctly,
I would guess that you should change colour cartridge as well (these I have seen deplete themselves trying print black when black ink is not present.
There is also a way of telling your printer to forget about alignment would you like to know how......Press and hold the Setup button, and then press Options (or Copy Options ).
Here is a link to how an alignment page should look and HP answers to your problem, please rate my solution for me.
Nov 21, 2007 | HP PSC 2175 All-In-One InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
old marine
old marine
