Question about Gigabyte Computers & Internet
Powers up but HDD just clicks. Tried several things...
Hi, I have a Packard Bell tower with a Gigabyte GA 8trc410mnf-rh motherboard. The computer powers up (lights up) but the hard drive just clicks and doesn't load. Here's what I've tried:
- Changing HDD for one I know works, same issue
- Tested HDD, worked fine in another computer
- Changed power supply. Both old and new power supplies working fine.
- Replaced SATA cable, same issue.
I've read another post that says replacing the motherboard doesn't help, any other ideas???
Thanks!
I have the answer - and it's taken me over 2 hours. Exactly the same thing, clicking and the HDD light at the same time. Disconnected HDD, still clicking. Replaced PSU, removed DVD, blah blah. Replaced CMOS battery, still clicking.
I had 3 cards on the go so removed them all - NO CLICKING!
Replaced TV and 1394 cards - NO CLICKING!
Replaced PCIe card and, you've guessed it, the clicking returned. I'm typing this on the PC I worked on and it's restarted perfectly every time. What I don't have is another video card to tell me if it's the card or the slot but guys & gals, removing the PCIe graphics card solved this for me.
What I cannot work out is how the HDD light flashed in time with the click (until I disconnected it).
Hope this helps - I'm off to bed.
All the best
DcR Computer
Posted on Sep 22, 2011
I have an identical problem with a Hewlett Packard PC, same motherboard. I have also tried all the above, and removed the cmos battery to reset the defaults, still no luck. One difference with my problem is that when cold the PC will now boot for 30 seconds and start loading windows, then shuts down. If I try again it only lasts for 12 seconds and dies. I suspect that something is failing either due to heat or a power down fault of some sort. Could be the chip, the board, or the memory, I don't have a spare board or chip to try. I posted this to show that the problem is not a once off.
Posted on Dec 11, 2009
  • 212 Answers
If the hard drive clicks, there's either a serious problem with the hard drive itself, but since you already tested with a drive that is sure to work, it has to be the motherboard. the other post you read, has probably nothing to do with your own problem. try reinstalling your system board's drivers or replace the system board if unsuccessful
Posted on Oct 05, 2009
  • pwhittlesea Nov 10, 2010
    We've just had one of these come in with the same problem too... Removing the HD connection and powering up produces a clicking sound with the HD light flashing. This is even before a post and the fans running at full speed. Goes no further. Have tried all the obvious... MOBO issue for sure...only annoyance is the OEM power button and LED connections - time to whip out the stanley knife splice the connector and put in a replacement mobo. This is the 2nd post I've read about this issue so thought I would add my experience on this so as others can also find it. Have fun replacing
Find a compatable motherboard to a gigabyte ga-8trc410mnf-rh imedia 1459 thanks
You probably have a Packard-Bell computer. You will need to match the motherboard form-factor to your case.
Nov 03, 2010 | Gigabyte GA-6WMM7 Motherboard
Hi ive got a GA-8TRC410MNF-RH Gigabyte mobo from a packard bell IMEDIA MC 2559 PC The mobo's P/N : PB34316801 I got a new case for my son to build a PC for the first time and we got this mobo from ebay...
as far as the SATA prob is concerned your mobo supports sata 2 as per the weblink
http://support.packardbell.com/uk/item/index.php?i=spec_SeagateTonkaII_Serial&ppn=PB34305801
Feb 14, 2010 | Gigabyte GA-6WMM7 Motherboard
Desktop powers up, but just clicks and nothing else happens
It maybe the power supply, if it is you should get nothing no lights clicks would be from the power supply.
Mar 15, 2009 | Gigabyte Computers & Internet
Uppgrade of processor!
Either there is a problem with the physical fitting of the processor, or the motherboard is not equipped to handle said processor, even with a bios revision.
Sep 27, 2008 | Computers & Internet
Uppgrade to a faster processor?
Hi
Pentuim D is a processor that has 2 x cpu in one and a core 2 duo has 2 cpu's plus 1 smart core bigger cache
you can only upgrade to a E2140 or E2180 processor on that motherboard
OR replace the board with a newer type
If you want to work the actual speed for the processor of a dual core take the speed for example dual core 1.8 x 2.1 =3.78 GHz
Core 2 Duo  1.8 x 2.4 = 4.32 GHz
Sep 23, 2008 | Computers & Internet
looks like that mobo can only suppoport up to 53 mhz front side bus for a celeron d processor
wht tht means is tht u can get any cpu tht has the front side bus up to 533mhz with the 775 socket forur motherboard
and forpentium 4 its 800mhz and agian any cpu with up to 800 mhz front side bus and 775
so ur best cpu for tht mobo would be the SL7RR it supports hyperthreading
here a direct link to intel'ssite
http://processorfinder.intel.com/details.aspx?sSpec=SL7RR
SL7RR
3.40 GHz
800 MHz
109.6 W
66
512 KB
2 MB
775
0.13 µm
yes
pls rate my answer if i helped u
Sep 22, 2008 | Computers & Internet
Computers & Internet Logo
502 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
