Question about Lexmark X4650 InkJet Printer
Cant copy A4 size
When i try to copy a document it prints only the centre of the document. I have tried to copy the document same size etc however the printing starts in the middle of the page!! Why? My machine is a X4650
  • 330 Answers
Give print...select printer ....goto properties of the printer in the same dielog box.....then ....more page layout options .....there you can change the page scaling
Posted on Oct 05, 2009
Center images
>> Check the paper is correctly inserted in the printer tray
>> Set guides exactly to paper size (Ex: A4 Paper Size)
>> Copy paste the image into a word document
>> Select the document press Ctrl+E in Microsoft Word
>> Try to Print.
Mar 23, 2014 | HP Photosmart C3100 series
When i press to copy it makes print but not all the page..then says load correct paper. down says A4R PLAIN COPY
A4 paper is used in Europe but some documents may be in that size. Try feeding legal size paper into your printer. Your document should be fully printed. Good luck !
Aug 22, 2012 | Canon Office Equipment & Supplies
HP PSC 2410 printing extremely slow
Hi
Thanks for using FixYa. The maximum speed of the printer is 8 pages per minute, which cannot be exceeded. This speed is measured using "Letter" sized paper. "Letter" is a U.S. standard paper size, which is smaller than European A4. Your print job may be very complex. Try the following:
  • Reduce the complexity of your document (reduce the number of multiple graphics, etc.).
  • Try a different graphics mode setting in the driver, under the finishing tab.
  • Try printing the document at 300 DPI.
  • If system resources are low, try printing with fewer applications running.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | HP PSC 2410 All-In-One InkJet Printer
Not able to scan and print as like copier
When you use a regular copier, it doesn't save, right? It just copies. That's the whole idea behind the Copy program that came with your scanner - for your scanner to operate as a copy machine. What you want is document management software.
Therefore, the very best solution is to download a (free) program that will convert files (Word, Excel, etc.) into PDF files. Click here for a list of such programs.
Suggestion: Never use image files for document management because they don't have any of the necessary features, such as the ability to search the contents of a digital document, the ability to comment, etc. And you want a program that will convert into PDF - try to stay away from other file formats as PDF (Adobe) is the "standard."
Mar 12, 2009 | Umax Astra 3400 Flatbed Scanner
Print A3 to 4xA4 pages on Lexmark X4270 All In One
Hi!
Please download this software for converting your dwg, dxg,etc files into jpeg---
Dwg to jpeg Converter
And, regarding printing in black color only, you need to give it a print command and the click on prefrences button and from there select print in grayscale and then you will be able to print.
Please ask for any further clarifications.
Please rate this solution as Fixya if found helpful.
Thanks
Rylee
Feb 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Network printing ok but word documents,e-mails etc problem
please make sure that the printer properties and printing preferences (right click the printer in the printer(&faxes) folder the paper sizes are set to match the printer,
then make sure that the documents you are printing are the same size.
on the kyocera printers you can also set a setting to override A4/LT
press: MENU, SCROLL DOWN, PAPER HANDLING > SCROLL DOWN, OVER RIDE A4/LT > ON, ENTER.
hope this helps.
Dec 15, 2008 | Kyocera Mita FS-1920 Laser Printer
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Will not print 4 x 6 prints
try to find the margin settings of the application that you are printing  with. If margins are setup in a wrong way it will print anywhere it likes.
Aso see the paper size. e.g. A4, A3 etc.
I think you should take a normal a4 paper and print it and see the size of the image and the size of the document that you have created.
Another way to test it is to copy the image(content) only and paste it in some other application like MS Word or something else and try to print it in 4x6.
If it is an image and you can copy it to MS Paint then do it and cut everything else (crop the image accordig to its' size), then print.
Remember to place the paper on the right hand side of the paper tray. (You can do the reverse also if it required.)
Sep 25, 2006 | Canon S520 InkJet Photo Printer
Lexmark X4650 InkJet Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
