Question about Samsung Digimax V800 Digital Camera
When switched on the lens comes out then the green light goes off the camera switches off but the lens does not retrack
Gwenivie
  • 39 Answers
SOURCE: S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Posted on Jan 11, 2008
  • 4090 Answers
SOURCE: my camera wont charge, everytime i try the light
The first question is how old is the battery?
Faulty batteries will cause this problem,
Posted on Sep 12, 2009
BillB-SA
  • 2761 Answers
SOURCE: Hi, my Samsung nv10 camera, when switching on,
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 14, 2009
SOURCE: lens stuck half way out
it seems that your cam and barrel assembly has been damaged. The worst part is that you do not get the spare part either from Samsung or any other vendor. if you get a solution please mail me
Posted on Sep 29, 2009
  • 10865 Answers
SOURCE: The camera doesn't turn on at all. Tried new
Hello. Begin by cleaning all of the terminals in the camera and all of the battery terminals with the eraser end of a common pencil. you may merely have a thin coating of corrosioin preventing you from getting a good connection and also a good recharge.
If that does not fix it, try these steps:
f your camera will not turn on, do the following:
  1. Remove all sources of power (batteries and AC Adapter) from the camera.
  2. Remove the Picture Card.
  3. Wait a full minute.
  4. Press the Power button twice.
  5. Connect the appropriate AC Adapter to the camera.
Posted on Nov 14, 2009
Testimonial: "I tried cleaning and leaving batteries out overnight, the only thing left is to try external power if I can find a suitable adaptor"
Nikon l810 doesnt switch on, green light comes on then goes off
you may need to set the timer longr to take the picture also be sure to open the lenses or remove the batttery yt reset be sure to used right can of batterys
Aug 27, 2012 | Nikon COOLPIX L810
Kodak easyshare v803 power's on but when lens goes out the power goes off retracking the lens and does not stay on
the coomon caused are lens blocked.
1.- clean the external surface of lens with can air compressed and a soft cloth
2. turn OFF your camera
softly PUSH the lens
3.- Softly PULL the lens while you turn ON the camera
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Cameras
Nikon Coolpix S610C dropped camera turns on and lens will extend but turns off and lens retracks in a few seconds. The on/off button does not always respond.
I got a same problem with different mode.
I planed to send it back to manufacturer, before packing it, I just knocked the back of camera with my palm in switch ON mode... the lens just retracted into normal position...
It can work for you to......
I am not an expert, it is just my experience I am sharing here.
If Lens struck with Lens Error!! on the screen, charge the batteries, switch on the camera, when the lens tries to move, feel free to knock a bit hard at the back of the camera with ur palm...... you cant hurt it any more than it already is., it might help the misplaced gears to aline back in if it is a minor problem.
Sorry about this un expert advice but it worked for me...
Just try it before sending in...
Feb 14, 2011 | Nikon COOLPIX S610c Digital Camera
The camera was dropped and the lens is extended and will not retrack. There is no control with the power switch
Try sending the camera to Panasonic Repair Center for immediate repair. They can help you repair the unit since it was hit badly during the fall.
Thank you.
Aug 01, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Turn on power, green light flashes, powers off
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Rokinon DZ1000 Digital Camera
The zoom lens don't retrack Display don't
Charlene, It seems that there some dust that has entered between the lens housing and the camera body. To remove it you must use the vacuum cleaner to pull out the dust from this place. And keep switching on and off the camera so that it tries to move the lens inwards/outwards. If this does not work then the movement mechanism of the lens may have got stuck and would require more serious efforts for which you may or may not have to tools and knowledge.
Nov 02, 2009 | Vivitar ViviCam 8400 Digital Camera
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Not powering off
lights flashing like that usually means something is wrong in the shut-down procedure. my guess (and is quite common ) is that the lens doesnt retrack all the way hitting a clitched gear spline or something, maybe just weak motor,....as your retry it it settles in proper and tells the micro its ok now to shut down. good luck
Sep 01, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Samsung Digimax V800 Digital Camera Logo
37 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
