Question about Maxtor Computers & Internet
I need the id info for a quantum lps52, cly--hd--pre--lz--sec--size
  • 212 Answers
P R O D R I V E L P S 5 2 A T QUANTUM NO MORE PRODUCED Native| Translation ------+-----+-----+----- Form 3.5"/SLIMLINE Cylinders 1219| 751| | Capacity form/unform 52/ MB Heads 2| 8| | Seek time / track 17.0/ 5.0 ms Sector/track | 17| | Controller IDE / AT Precompensation Cache/Buffer 64 KB LOOK-AHEAD Landing Zone Data transfer rate 1.750 MB/S int Bytes/Sector 512 4.000 MB/S ext Recording method RLL 2/7 operating | non-operating -------------+-------------- Supply voltage 5/12 V Temperature *C 4 50 | -40 65 Power: sleep W Humidity % 8 85 | 5 95 standby W Altitude km -0.060 3.000| -0.060 12.000 idle 5.5 W Shock g 6 | 60 seek W Rotation RPM 3662 read/write 6.5 W Acoustic dBA 45 spin-up W ECC Bit 48,WITH 11BIT BURST COR MTBF h 60000 Warranty Month 12 Lift/Lock/Park YES Certificates CSA,FCC,IEC380,SDA,TUV,UL4...
Posted on Oct 05, 2009
How can i program id caller for kx-t7330
Depends on line type, if ISDN lines caller ID is built in, if analogue lines you will need a cli card, tI display cli press TRSF while the phone rings, if you have subscribed to the caller I'd service of course
Oct 09, 2013 | Panasonic KX-T7630 Corded Phone
I have a Snap Server which is close to 10 years old. Inside the Snap Server are two Quantum Fireball CX 3.5 Series drives. How do I tell the size of these drives?
> Quantum 13Gb FIREBALL CX
What is printed on the labels on the top of each disk?
What is the model-number?
Do a GOOGLE-search on that model-number, to see what others have written about that model,
including the "specifications".
Nov 13, 2010 | Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n...
Quantum fireball 3.5 series HD that crash NEED to retrieve data
what error do you get on pc startup?
Alternatively you could try getting an external casing by putting the hard drive in there and try accessing the info from there.
Oct 26, 2009 | Computers & Internet
Hipath 3550 CLI on ADSL Line
Try #86 on each handset to enable CLI and *86 to suppress CLI.
From V3 to V7 is big. Motherboard upgrade.
Sep 07, 2009 | Siemens HiPath (L28155H5100A402) IP...
Need to know the slave jumper for the quantum atlas iv hd
If the drive you're referring to is the SCSI model, it doesn't have a "slave" option, but can be set to various SCSI ID's.
Click this link to get the skinny on all your jumper options:
http://support.dell.com/support/edocs/storage/6848p/Jumpers.htm
If you are using it on an older MAC it should work fine set to ID 1, if you want to use it on a PC check first if the PC even has a SCSI connector(rare for PC's of the same age as that drive as they primarily used IDE). The cables look almost identical but are in no way compatible
Hope this helps FixYa
Chris
Armor-IT
Apr 25, 2009 | Quantum Atlas IV (QM309100KN-SCA) 9.1 GB...
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Quantum fireball 10.2gb
    The computer speed completely depends on the speed of quantity of RAM, HDD, processor and FSB of mother board. Your processor is good enough to give better result with windows XP and did not mention about the availability RAM, if less than 256 MB, you need to upgrade and you can upgrade HDD not so mandatory if you have more than 20% free space. Under maintenance practice do regular "DEFRAGMENTATION and CHECK DISK" from selecting driver properties under tool tab.RAM will surely give boost and do degramenation
    Apr 16, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
    Error:u043
    1st step: Press and hold the Stop/reset button for 5-10 sec then release. I
    f ot working then use a Qtip and moisture (not wet) it with water. Cleans the chip gently and re-insert it back and redo the 1st step.
    It work for me everytime!
    Nov 02, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Computers & Internet Logo
    306 people viewed this question
    Top Maxtor Computers & Internet Experts
    Arora Singh
    Arora Singh
    Computer Links
    terminalcon
    Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
