Question about LG 42LG50 42 in. LCD HDTV
Interference problems i got my tv just over a week ago. it was fine for the first few days but now if you turn on the other tv in my house the reception on mine drops out.
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
Please check any coaxial splitters, replace any defective splitters and install a signal amplifier to correct your issue.
If you have cable, the cable company will do this for free usually.
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Oct 05, 2009
Green and black screen when I use turn Direct TV box
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
Tv wont turn on
Same Problem. TV was purchased from Sams Club about 2 or 3 years ago. workede great unti llast week. We were watching tv and it just shut off. The power button on the tv started to get soft were you had to push hard or just use the remote. My guess its something with the wsitch.
Jan 28, 2009 | Sylvania 6427TE 27" TV
TV flickers intermitantly
loose con some where in the set very time consuming
Dec 03, 2008 | Televison & Video
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Philips HDTV does not turn on
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Flashing LInes across my screen...
have it looked at immediately before more chaos happens
Jan 02, 2008 | Radio Shack Cinego D-1000 Multimedia...
Sound Interference
NO it dosent sound like there related problems at all. Now you say you get interferance or is it more like a static noise only when using the dvd player??? If thats the case then you have an output device problem as its breaking down and crackling into your input to your sound amp or the tv. Its a problem that will need to be traced with a scope and a test disk. as it could be a D to a converter or an op amp IC, or even as simple as a filter cap. Good Luck
Apr 10, 2006 | JVC DRM10 DVD Recorder
LG 42LG50 42 in. LCD HDTV Logo
74 people viewed this question
Computer Repairing
Computer Repairing
