Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
My wireless doesnt broadcast. im using a dlink dsl 2740b router
    Problem Solver:
  • 6 Answers
Under your wirless tab. Make sure Enable AP is ticked. You have named your SSID, usually the same name as your workgroup network.
In windows your workgroup is called WORKGROUP.
Chanel is set from 1 to 13
Security is set to WEP
Authentication Type is set to OPEN
Encryption key password is set to a 10 hexadecimal code.
ie: abcde12345 ( choose something you will remember)
On the device you are recieving make sure you have the same password, SSID, Same chanel as router and is set to WEP. If they are not the same then the units will not connect.
This should resolve your connection. When you first connect have the two units close to each other and reset the router. Then reset your other device. If it does not connect chect the antenna is screwed in firmly but not too tight to the router.
If it still fails then change your chanel up or down on both devices. Does not matter what channel you choose just as long as they are both the same.
Posted on Oct 05, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
Problem with modem router DSL-2740B
1.Reset-
The factory reset button is located in the back panel of therouter, and requires a thin, sharp and robust object (like anunfolded paperclip) to be pushed in.
To factory reset, power up the device and wait for 1min. Pressand hold the reset button until the STATUS LED turns off. Releasebutton and wait 1min.
2.Update the firmware-download the required files from the D-Link Support page
3.Contactct your ISP
Jun 13, 2012 | D-Link Wireless-n Adsl2 4-port Modem...
Low signel strength
Common with single antenna routers and adsl/router boxes, i use a zoom x6 adsl with wireless and i was having similar problems , it also has a single antenna so i disabled its wireless feature and got a linksys rangebooster router dedicated to my wireless needs, has good range and its durable, Im basically suggesting that you get another wireless router with dual antennae and use that for your wireless needs, hook that up to your DLINK modem via ethernet cable and disable the dlink's wireless feature...Hope this helps..
Oct 27, 2010 | D-Link DSL-G604T Wireless Router
PPP Password doesn't match error
1. You should better check the power supply if it is plug on, properly on a 220AC Voltage. 2. After installing your disk suppose to be you should reset the configuration of your DSL 2740B so that it will restore back to the main configuration of the system. (to reset your DSL 2740B try to look for a small button on it. then press according to standards then your done. Good luck and i hope this steps will help you accurately. God Bless.
Apr 07, 2010 | Zoom X6 Adsl Wireless Gateway Rohs Router
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
D-link dsl - 2640u ' the lan is up but wireless no...
i have a dlink dsl2640u when i go in 192.168.1.1 and try to turn on the wireless and save it reboots 3 to 4 times then it stays on but the wireless is off any help
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
DLink router connected to internet but webpage doesnt open
With an Ethernet cable, connect your computer _directly_ to the cable-modem (or DSL-modem), bypassing the D-LINK router.
Now, can you web-surf?
Sep 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I cant connect my wireless n router to my internet connection
hey can you see your router pppoe connectied to you pc or laptop
Jul 05, 2009 | Computers & Internet
Dlink wireless router software download
Click the link below for D-Link Downloads
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2750B
or try the link below
Click or copy the link to D-Link Support and past to your address bar
After page opens type DSL in the first box on left
Then in second box scroll down to your model number
May 23, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
236 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
