Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
The settings dont stay. every time i turn on the camera, i have to put in the settings of date time and everything
4 Suggested Answers
SOURCE: Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Posted on Dec 15, 2007
  • 374 Answers
SOURCE: set date and time comes up every time i turn on camera
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Posted on Mar 30, 2008
  • 11967 Answers
SOURCE: My camera is not storing the lsettings
The next time you finish entering the info, press the button you use (menu/set/enter or whatever) twice.
Posted on May 03, 2010
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Tip
DATE RESET PROBLEM ON DIGITAL CAMERA
Have you encounter on your camera that the TIME and DATE are always cleared once you turning ON? Menu of the date setting appears everytime inserting the battery and turing the power ON?
Dont worry the problem of your camera is only a minor. For your technical information, all cameras have a capacitor together with board that provide power to save your date setting or its work as a battery.
Once you open you camera and you found out color green stain can be seen in the part of the said capacitor. You need to clean first by brush and make it sure be gently while brushing the capacitor just to remove the stain.Then try to turn On your camera and set the date and time, after this turn off and remove the battery for a second. Once again put the battery on your camera and turn On. Once you need to set the date again it means the capacitor was damage and need to replce new.
if you have knowledge about repairing electronics what you need to do is remove the damage capacitor and replace it new with the same specifiction and size.
I hope my tips will help you
Good luck and thank you
on Jul 21, 2010 | Cameras
The date and time will not stay after setting, is there a flash update?
This is a firmware glitch. If you disable the startup image, the date and time is not saved. To fix this issue, you must re-enable the startup image.
Turn on the camera and press Menu (M). Press the right side of the circular directional button to select the wrench. Press OK/Edit.
Next, navigate down to "Opening" and press OK/Edit. Select ON and press OK/Edit. Go back up to Date/Time and set the date.
Restart the camera to see if it works.
Jan 19, 2010 | Polaroid i1035 Digital Camera
Date and time setting dont save, I changed the CR 1220 battery. Still doesnt save. Every time I turn on the camera the date / time setup appears.
In another forum I found a solution:
Remove the watch battery from the camera
Carefully bend the contacts inside the camera toward the opening that the battery fits into. - I used a heavy safety pin to bend the contacts.
Put the watch battery back in.
http://forums.steves-digicams.com/canon/131158-canon-720is.html
Aug 16, 2009 | Canon PowerShot S5 IS Digital Camera
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u!!!!
May 26, 2009 | Canon IXUS i7 Digital Camera
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Date & Time will not stay current
same thing happened to me too! lol. However after you press the menu button and click "default setting", go set your date and time again. Then turn the camera off. Turn it back on and you will find that the date/time is correct!
Jan 03, 2009 | Polaroid i1035 Digital Camera
Sony DSC-W150 power on keeps going to set date/time
The date and time settings are displayed after turning on the camera. Solution
sp.gif sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  1. Turn off the camera.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 23, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
21 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
