Question about Microsoft Xbox 360 Console
2 red lights on the left hand side. comes back on for 5-30 minutes then goes off red again.
    Genius:
  • 1,093 Answers
Yes give it a good dust out if that does not work you will need to send it in or repair it yourself using a proven Xbox 360 Repair guide
Posted on Oct 05, 2009
    Problem Solver:
  • 11 Answers
Your xbox 360 console is overheating. Make sure all your vents are clean and unobstructed. Allow to cool for a few hours. If problem persistes you'll need to contact microsoft. May be an issue with the cooling fan
Hi everyone. i have a b.m.w X5 2004 with xenon headlights ....had an accident and had to change both lights........ after changing the right lights goes on but the left doesnt so i tried switching them and...
check headlight to ground connections, headlight relay, light switch.
the ground connection is the most likely cause, during the accident the wires were stretch/pulled/moved more than likely causing the ground wire for the lights to disconnect or become loose.
Dec 16, 2013 | 2003 BMW X5
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit
Jan 07, 2011 | 2003 Jaguar X-Type
TV works fine for about 3 minutes then the picture goes black and the red light on the front of the TV starts blinking. The sound works the entire time. If I shutdown the TV and wait a few minutes and...
The light is blinking a code. The code will be a series of blinks, a pause and the blinks again. Phone Sony service and give them this code. They will be able to advise you as to the problem.
Apr 03, 2010 | Sony KP-53HS30 53" Rear Projection...
I have a 50'' Philips tv. When I turn it on the picture comes on fine, within a matter of minutes the picture goes out and this red light comes on highlighting a tiny picture of a light bulb on the ''on...
Sounds like your lamp is bad. I think this is the set where you have to take the whole back off to replace the lamp. Once you take the back off, its on the left hand side.
Dec 02, 2009 | Philips 50PL9126D/37B 50" DLP TV
2003 saturn vue service light on with wrench how do I reset
Open the hood. You will notice there is a large black box on the right-hand side directly behind the battery. This black box is the fuse box. Pull the top of the fuse box off. There are two clips on either side; once you pop one side, the other comes off very easily. In the top left-hand side of the fuse box where all the fuses sit, you will see a large orange/red block. Below this block is a button that says "reset." Press this button for 5 seconds. Turn the car on and wait for a minute. If the light does not go on, turn off the car and set the key to ACC on the key ring. Push the reset button again, holding it for a total of 15 seconds. Turn the key to off, take out the key, return the key and start the car again. Allow the car to run for 2 full minutes. It is taking the system a few minutes to register that this button has been pressed.
Sep 01, 2009 | 2003 Saturn VUE
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Tire pressure light
On the lower left hand side of the dash, near the Traction control button, is a small push button. Just press and hold until the Tire Pressure light goes out. Of course, make sure you're pressure is ok, otherwise, it will just come back on in a couple minutes.
Aug 04, 2008 | 2004 Toyota Camry Solara
Blinking screen
ON THE 36 INCH SONY THE PROBLEM LIES ON THE PICTURE TUBE.THERE IS A LEAKAGE EITHER HEATER TO CATHODE OR G1 INSIDE THE CRT.THE ONLY WAY TO FIX IT IS REPLACE THE CRT OR HAVE THE CRT GUNS CLEANED THRU PICTURE TUBE TESTER/RESTORER/REJUVINATOR AVAILABLE ONLY FROM TV TECHNICIANS.GOOD LUCK.4TUNE.
Jan 09, 2008 | Sony KV-35S42 35" TV
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
