Question about RTO 4 wheel Heavy Duty Mobility Electric Power Scooter
Hi it keeps stopping,leave it 5 mins and it will go again for a short while.
  • RTO Master
  • 1,271 Answers
Sounds like the brushes could be worn out,
Connection form the batteries to the motor controller then check the M+ M- leads from the controller to the motor
Could be the controller breaking down
Batteries are okay ? or simply the speed pot is worn,
when it stops , move the throttle lever upwards, does it start to go again, if so a new speed pot is required.
Regards
Gewiz.
Posted on Oct 06, 2009
Touch screen not working
is it just the touch that stops working? or all off the computer?
May 22, 2014 | Toshiba Satellite Computers & Internet
Pto clutch electrical
1. Check battery (specific gravity and load test). 2. Check voltage going into battery while running without and with pto engaged. 3. Make sure unit is running at full throttle whenever electronic PTO is engaged otherwise it wont keep battery charged up.
Feb 24, 2014 | Garden
My 1998 buick century 3.1 will not start. I changed starter , I changed the ignition switch , I even jumped the battery to starter with a push button , It now will turn or crank , but ,, it still will not...
THERE IS A CHIP IN THE KEY I BELIEVE. THERE IS A RELEARN PROCEDURE YOU CAN TRY IF WHEN YOU TRY AND START IT THE SECURITY LIGHT FLASHES. HOOK UP A BATTERY CHARGER. TURN THE KEY ON AND TRY AND START THE CAR AND RELEASE . DO NOT TURN KEY OFF LEAVE IT IN THE RUN POSITION. AFTER 10 MINS THE LIGHT WILL STOP FLASHING. TURN KEY OFF. TRY AND RESTART CAR AND AGAIN DO NOT TURN KEY OFF LEAVE IN THE RUN POSITION. LET SET 10 MINS AGAIN. LIGHT WILL STOP FLASHING AFTER THAT 10 MINS. DO IT AGAIN FOR THE 3RD TIME. SHUT KEY OFF LET SET 5 SECONDS AND START THE VEHICLE. HOPE THIS HELPS
Feb 22, 2013 | 1997 Buick Century
My Sony Dolby digital keeps flashing "protect" when i turn it on, how do I make that stop so it plays sound again
hold the power down for 5 secs and it will go itno demo mode and then push the power power agian and it will trun off and thenn push th it one more time and that should work and if that does not work unplug it and leave it unpliged for at least 5 mins and then plug it back in .
Jul 17, 2011 | Sony STR-DE545 Receiver
HOOVER U3524 KEEPS STOPPING
its overheating check to see if its cloged any where look behind brush roller
Feb 08, 2010 | Vacuums
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
Whirlpool fridge stopped working. Actually somehow
This is an indication of a direct electrical short. Unplug refrigerator and do not use until the problem has been repaired! Sea Breeze
Mar 27, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Over heated hover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632385
Generic problem for all Vacuums
Over heated hover
Posted by blade123 on May 29, 2008
Hi there, I’ve got a upright Hoover and it cuts out after about 5 mins I think it’s over heated but if i leave it for 5 mins it works again but cuts of again how can i fix it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you my have a heat sensor, but as far as what you described you need to change both belts, the brushroll belt and the power drive belt as well and @ the same time. The average belt change is every 4 to 6 months on the vacuum. Does it stop completely or is it just the belt problem. Or #2 is the vacuum giving off a burning smell other than the belts and if it does it could be the motor. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
RTO 4 wheel Heavy Duty Mobility Electric Power Scooter Logo
185 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
