I have a JVC TV model LT-26A70SU My inputs via the SCART cables are E1 for satellite TV & E2 for the DVD player. For some reason, the E2 position has changed to S2 (indicated in the top right hand corner of the screen) which means the picture is now in Black & White! If I change over the two SCARTS, then the pictures are reversed. I then have the Satellite in Black & White & the DVD in colour. How can I change the S2 back to E2?? many thanks, David James email: djtorquay@yahoo.co.uk
  • 19,396 Answers
It is not a setting problem. It is one of the two scart cables that is causing the problem.
Try replacing the SCART cable that gives you the black and white raster, that should fix the problem. Let me know if it does not.
Thanks.
Posted on Oct 05, 2009
What cable do i need to connect philips dvp3520/05 to hd tv
The DVD player only has a SCART out and unless you have an European model TV it won't have a SCART input. So you have to buy a SCART to RCA cable and connect the RCA end to the TV's AV input ( Yellow to Video and Red/White to audio input )
Mar 17, 2011 | Philips DVDR3380/05 DVD Recorder
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
I put a regular dvd into my blu ray player but it will not play. the player just says load and when I push the play button nothing happens. I'm using an hdmi cable and my 42 i.nch widesreen sharp tv is set...
Assuming it will play regular DVD's I'd suggest you connect it by scart also and set your TV input to scart.
I don't think DVD's carry High Def. data, that being the case, your player may auto route the data via scart.
Mar 31, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
How do I connect a JVC DVD video player model XV-S302SL to a cable box and a TV
There are several ways in which you can do this.
The first way. If your cable box has two scarts one will be label as tv and the other vcr or something similar. connect your Dvd player via scart to the vcr scart on the back of your cable box. then connect a scart from the cable box to the back of the TV.
That would be you all sorted. when you turn your DVD player on this should override your cable and display the dvd screen.
Second way. If your cable box has not got two scart ports on the back of it. Then you would have to connect both to the back of your TV. If there are not two scart ports at the back of your TV then you can purchase a scart lead splitter. I would imagine the Cheapest you could find would be on Ebay or something similar.
Hope this Helped Clarify things for you.
If this has then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 14, 2009 | Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Connect jvc combo vhs/dvd recorder to satelite and tv
If your satellite box has two sart outputs. Scart1 should go to the Tv Scart 2 to the input on the Video. Then the output scart socket on the VCr should go to Scart 2 on the TV
Sep 23, 2008 | Televison & Video
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
Jvc lt40ds7bj
What model of DVD player do you have? The RF cable jacks on dvd players are only for switching the RF. All players always use AV input/output or Component input/output, the later is the best.
May 12, 2008 | Televison & Video
DVD/VCR combo won't record off of the t.v. even after programmed
Do you have a scart lead connected to E1 or E2 on the recorder.
Feb 19, 2008 | Televison & Video
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
