Question about Blitzz Technology (BWA611) Router
Blitzz router and XBOX 360
How do I get 3 ports opened on my router in order to get XBOX 360 live?
Is there a phone number for them out there? The only one I found is no longer in service.
Jeff
  • Anonymous Dec 23, 2007
    my connection is slow & lagging with many interruptions
  • Anonymous Apr 15, 2008
    i have a similar problem. my live test fails at mtu even though live only requires 13-something mtu's, my routher says it defaults at over 14-something mtu's. any suggestions?
  • 556 Answers
Review this link in terms of DMZ and Port Forwarding, you need to use one or the other. It will need to be adapted from a Linksys to a Blitzz router
http://www.ianarchbold.com/xboxlive/index.html
I you need additional assistance leave a comment here on the problem and I will attempt to provide a solution.
Posted on Dec 22, 2007
Im trying to connect to live and I connected to the internet but not xbox live
Xbox live requires some ports to be open on your router. Make sure the following ports are forwarded through your internet router to the IP address of the Xbox.
On Xbox's site below they have some instructions for the most common router manufacturers.
From the Xbox website: http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/kb/xbox-kb.aspx?kbid=908874
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
Note If you cannot chat with someone using Video Kinect, you might need to open port 1863 (UDP and TCP).
Mar 03, 2011 | Computers & Internet
My ports are not open and my internet say you nat type is moderate
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Jul 01, 2010 | Microsoft Xbox 360 Elite Console
My xbox 360 live picks up belking54 but wont connect
Hi Kevin,
Please check whether you have opened the Port numbers for your XBOX 360,If tis not open please collect the Port numbers from the XBOX Vendor,so that we can open particular port numbers.
Regards,
Ayyasam
Apr 03, 2010 | Belkin (F5D7230-4) Router (587009)
Xbox nat setting
Mar 07, 2010 | Microsoft Xbox 360 Controller
Xbox360 elite
contact the router company have them walk u through make sure these ports are open
If you have not already forwarded ports for your xbox through your router then that may be your problem.
The following ports must be available to your Xbox 360 console for Xbox LIVE to operate correctly:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • May 27, 2009 | Microsoft Xbox 360 Console
    Need a telephone number to contact my router company
    No you dont need to contact them..
    just go here and follow the instructions
    Good luck gaming!!
    Please rate this answer
    Jan 19, 2009 | Blitzz Technology (BWA611) Router
    My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
    hi,
    in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
    for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
    Dec 29, 2008 | Linksys WRT160N Wireless Router
    Cant have private chat or play games with friends
    This should solve your problem
    For most devices that use NAT, port forwarding is not required to connect to Xbox Live. This is especially true if you use an Xbox Live certified device. Sometimes, you may have to configure port settings on a non Xbox Live certified router or gateway.
    If there is a firewall device between the Xbox console and the network device, you may have to configure the firewall to enable communication on specific network ports. If the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," you may have to configure port settings.
    The following ports must be available for Xbox Live to operate correctly:
    � UDP 88
    � UDP 3074
    � TCP 3074
    To open the ports on your router see this handy website here,
    http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
    which gives you a step by step guide.
    Before opening the ports you must give your Xbox 360 a static IP address (manual) be sure to use an IP address that no other item on your network is using and is fairly high up in your range, for example if your router's address is 192.168.0.1 then you should use something like 192.168.10 for your Xbox 360.
    You can also enable DMZ (Demilitarized Zone) on your router, which will open up all the ports to your Xbox 360, however NEVER use this on a PC's IP, see your router's manual on how to do this.
    Once the correct ports are open for your Xbox 360, then your NAT should say open.
    Nov 26, 2008 | Microsoft Xbox 360 Console
    Connecting xbox 360 to laptop for xbox live.
    This site has all the info you need to connect your xbox 360 to a laptop and then wirelessly to live :) :
    [url=http://howtoconnectwirelesslytoxboxlive.blogspot.com/]How to connect to xbox live wirelessly[/url]
    Oct 26, 2008 | Microsoft Xbox 360 Console
    Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
    To make a router connection to Xbox Live:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console with no disc in the disc tray.
    8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
    Jul 02, 2008 | Video Game Consoles & Games
    Blitzz Technology (BWA611) Router Logo
    111 people viewed this question
    Top Blitzz Technology Computers & Internet Experts
    Michael Galve
    Michael Galve
    Tre Elkins
    Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
