Question about Delta Cycle Rothko Rolling Bicycle Stand
Change blade miter saw
Delta 10" compound miter saw; model: 36-225 I do not know how to change the blade
    Problem Solver:
  • 7 Answers
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Posted on Oct 05, 2009
  • Bill Foster Oct 18, 2011
    Is the nut standard. Clockwise or counterclockwise to loosen ?
MOTOR RUN FINE BUT BLADE BARELY TURNS
Posted on Jun 12, 2013
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
How do I replace a blade on a Delta 36-585 miter saw
There should be a wench on the mecnine that fits the bolt. the bolt turns in the oppiste derection as a normal bolt its called left handed thread this keeps it from coming lose during use. There is a buttom you need to press to lock the shaft then lossen to bolt lift the blade gaurd replace the blade note the washers that go up against the blade and make sure you install then in the same order as they were removed
Dec 17, 2010 | Delta SM100M 13 Amp 10" Compound Miter Saw
How to change the blade?
I don't know if this will help you much but I've got a DeWalt 14 inch chop saw and a 10 inch miter saw and they both have a small lever on the right hand side of frame just behind blade If you depress this lever and slowly rotate blade until it drops into place this locks the blade for changing. Hope this helps you. Thanks.
Nov 22, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Manual for Delta 10" compound miter saw 36-220
The Instruction Manual for the Delta 10" 36-220 Miter Saw can be downloaded from the following site:
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=36-220&selectedType=10255
Note that there are three models of this saw. The model numb r on your saw will be followed by -1, -2 or -3.
Select the model number you have from the on-screen drop down box. When the page refreshes download your manual by clicking the icon under PRINT DOC.
Sorry someone has not responded sooner.
Sep 14, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Need manual for Delta 10'' compound power miter saw MS 250
If you can't print from your computer, or local library, find a local print shop or copy shop that is willing to download and print a .pdf file for you.
Then go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Mar 18, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Delta Cycle Rothko Rolling Bicycle Stand Logo
551 people viewed this question
Top Delta Sport & Outdoor - Others Experts
Are you a Delta Sport and Outdoor - Other Expert? Answer questions, earn points and help others
