Magic Sing Along Consumer Microphone
Problem for Magic Sing Along Consumer Microphone
Distortion within a certain frequency range for wireless mics on magic sing 11000
By FatStratCat on Dec 22, 2007
We get this bubbly distorted sound from the speakers on the wireless mics during singing, we have two of these mics and they both do it. It most typically occurs in the higher vocal frequencies, high alto range. It happens more to female singers than male.
I've tried to adjust system volume, music volume and mic volume. Currently we have the mics set at about 4 or 5, and the music volume is higher but balanced, and then the system speaker is higher to compensate for the low mic volume and that seems to reduce the problem, but it still occurs sometimes. It seems as if the mics are extremely sensitive, or that extreme sibilance occurs within a certain vocal frequency range, causing this distortion. Has anyone else reported this, is there anything that can be done?
We had to send both mics back to the manufacturer when we first got them, because they only worked within about 7 feet of the unit. That problem got fixed, but since then we have been having this issue.
Would a simple windscreen fix it? I'm at a loss on how else to fix this, short of sending it back to be checked again and having to pay shipping both ways like we did the first time.
Best Solution
posted on Dec 24, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Because of the very wide dynamic range of the human voice, specially when singing, the microphone you use, needs to be smart(usually expensive) to do the job properly. When going cordless, the electronics needs to be even smarter. A windscreen will not solve the problem.
I do not know of ANY low-cost radio mic that would not frustrate you for ever and a day. Rather spend a little more and be happy.
If allowed, I can introduce you to a very budget tipe entry level radio mic, that would work much better: Beyerdynamic OPUS 168 mk2 This mic works on a diversity UHF frequancy that receives a very clear signal for at least 100 feet. It also works with a "compander" , that improves the dynamic range. You will propably pay about $300 for it, but it will last lots of years with much less frustations. Sorry, there is no inexpensive way out on this one. PA Master
Popular Solutions for Magic Sing Along Consumer
Questions and Unsolved Problems for Magic Sing Along Consumer
Do you recommend Magic Sing Along Consumer Microphone?
Answer
Answer
siempre la puntuacion es 100.lo que me parece es un daño en el equipo. por fabor ayudame.... (More)
Answer
I have an ED-11000 Entertech Magicsing karaoke set. One of the wireless mics runs out of charge only... (More)
Answer
our magic singalong microphone that we bought in the philippines suddenly stopped working properly.... (More)
Answer
no power on magic sing and wondering if it's fixable? tried battery and different outlet for ac/dc... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Magic Sing Along Consumer...:
Top Microphone Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Microphone Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
