Question about Food Mixers
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
Hi
I have just bought
POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP. However, it has come with no fitting instructions. It has three connections under the tap with three hoses. Two long hoses which I take it are for the hot and cold feed and one smaller hose. What is that for? It has also come with a big sort of rubber ball and I cannot see where this fits.
Can you please help
Hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Posted on Aug 19, 2011
Kitchen Aid Classic Stand Mixer beater stops when it touches anything.
Very much the symptom of a worm (follower) gear needing replacement. Three are videos of this posted on the net and you can find the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 09, 2013 | KitchenAid K45SS Classic Stand Mixer
Bolt that holds mixer on stand came out and will not fit back in to hold mixer in place
stripped bolt or hole? might need a tap and die, if lucky just a new bolt
Feb 05, 2013 | KitchenAid Classic Stand Mixer
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
Sep 28, 2012 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My kitchen aid mixer bowl falls out when I'm mixing
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
Aug 12, 2012 | KitchenAid K45SS Classic Stand Mixer
How do I get an owners manual for Kitchen Aid Ultra Power Model KSM90 stand mixer? I was given the used mixer and I do not know the frist thing about it.
Hi PASTYJOHN, it's very easy to download both the Owners Manual and Parts List manual for your KA mixer. You can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> then enter the visitor type "Consumer" and enter the 6 character model number, in this case KSM90P, where you can choose one of the three size files under Owners Manuals (20). Since there are three versions - 191.99 KB, 2730.37 KB or 3230.97 KB, I would download all three and save the one you feel is best for your needs. Similarly, I would also download a parts list manual, too. Since the Parts List manuals are exactly the same you can choose any one of the 16 available to download and save.
Good luck, I hope this helps. Howard, Burke, VA, USA
If this solution was helpful, please rate it, thanks! - hslincoln
Feb 11, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid Ultra Power Stand mixer manual or instruction how to oil.
Hi RFRICK753, There are no specific instructions to 'oil' your KA mixer. Your KA mixer's internal gears are factory packed with enough grease to last, with normal use, pretty much a lifetime. As grease will, over time, tend to break down, you may find the oil component of it seeping from openings beyond the gasket and "O"-ring down the agitator shaft. Gravity can be very insidious. But generally speaking if your mixer appears to be operating normally as it has in the past, you should not be overly concerned about 'oiling' it.
If, however, you feel it necessary to perform some TLC on your mixer, the good news is that the inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> then enter the visitor type "Consumer" and enter the 6 character model number, in this case KSM90P, and select any file under Parts List (16); say KSM90PSAC0.pdf (354.08 KB) for example (all 16 manuals are exactly the same, but it's still wise to check and see if it matches your mixer, though).
Although not providing step by step instructions, the Parts List manual provides an exploded view of the various component assemblies allowing you to see how the mixer all fits together. It is helpful for the disassembly, troubleshooting, and reassembly of your mixer.
You'll find it quite messy 'under the hood' in the transmission box, but you'll be able to ascertain whether you really need to re-grease or not. Also, while your mixer's apart is an opportunity to check for any other unseemly wear and tear on the gears, etc.
After getting your hands this dirty, you may want to order a transmission gasket, an "O"-ring, along with some food-grade grease. Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to peek under the hood and assess any maintenance needs for your mixer.
Jan 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have lost the manual and need the directions for use of the Kitchenaid mixer 5 quart
HI JWPERCY14223. It is very easy to download the
The inspection and troubleshooting of the mixer transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and select “Consumer” for User Type, then enter the 6 character model number, in this case K45SSW, and then select the first file under Owners Manuals (2) K45SSWH-0.pdf (2730.37 KB) (be sure to check that it matches your mixer).
The first file is the full 86 page ‘Instructions and Recipes’ manual in English that was originally included with your mixer. The second file is a 60 page multi-lingual (English, French and Spanish) Instruction manual without recipes.
While you’re downloading the Owner’s Manual, I would recommend downloading the accompanying Part List Manual, too. Select the file under Parts List (1) K45SSWH0.pdf (341.41 KB) and save that on your computer. If your ever have to troubleshoot or repair your mixer the Parts List manual will be an invaluable document to have on hand when taking your mixer apart and reassembling it.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer for your future reference, too.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! – hslincoln
May 03, 2010 | KitchenAid K45SS Classic Stand Mixer
Dismantling a KSM150 - HELP !!!!! :)
Hi G_MERRY, it sounds like you’re well on your way, great! You’ve got the correct Parts List Manual from KA, 5KSM150PSEWH4.pdf (777.26 KB), and you’ve started to disassemble your mixer using the exploded view on pages 4 and 5 entitled “Case, Gearing And Planetary Unit”.
The first two screws (Illus. No. 25) you removed from the back only secure the trim strap and the trim strap is only for decoration. To get further ‘under the hood’, you will also need to remove the screw at the top of the End Cover (Illus. No. 24) as well as four larger screws (Illus. No. 30) on the bottom of the mixer head before you can separate the Gear Case Motor Housing (Illus. No. 1) from the Lower Gear Case (Illus. No. 18). You will need to remove the planetary ring (Illus. No. 35) to access the planetary ring and agitator shaft, too, if you are completely re-greasing your mixer, as that seems to be your intent.
To continue to disassemble your mixer you will need a regular and Phillips screwdriver, snap-ring pliers, a small drift pin punch and a small hammer. By using the exploded views in the Part List manual, you should be able to disassemble, inspect, identify and replace broken/worn parts, and reassemble your mixer. The Parts list manual doesn’t provide that step by step assembly instructions that would be nice, but just a general idea of how all the parts fit together.
Here are links to three excellent websites that detail the disassembling/reassembly of a KA mixer that will be really helpful in your circumstances.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, and feel comfortable doing it.
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 24, 2010 | KitchenAid KITCHEN AID 5 Quart Artisan...
The chrome ring on the motor head of my 4 1/2 quart Kitchen Aid stand mixer has come off. It is the ring just above the beater shaft.We have put it back on, but it keeps slipping off. Is there a...
Hi BRET, that chrome ring is called the ‘Planetary Drip Ring’ and is a compression/friction fitted piece that should stay on during normal mixer use. Its purpose is to prevent the mixer’s transmission lubrication grease/oil from dripping into your mixing bowl from the planetary drive, hence its catchy name. It should be on tightly enough that to remove it you need to gently tap the edge of the ring with a straight screwdriver at several points on the ring. Obviously something is awry. Before going to the point of replacing it, though, you might try these three remedies first.
1) The drip ring may only fit tightly on your mixer in one orientation and you just need to ‘discover’ that correct orientation. Mark the outside of the ring with a small piece of tape so you can keep track as you rotate the ring around the mixer head flange. As you attempt to seat the drip ring, if it will not stay on, then rotate the drip ring clockwise, just a bit, and repeat the process. Ideally you should find one position where the drip ring will fit securely and stay in place. Give the drip ring one final squeeze for good measure. Keep an eye on the drip ring the first few times you use the mixer to make sure it is not working loose again. If that doesn’t remedy the problem, then…
2) You might try a little friendly persuasion by gently tapping the bottom of the drip ring with a few taps of a soft faced mallet or hammer (use a piece of wood between the hammer face and the ring to protect the ring) around the ring to see it that seats it any better, and...
3) If it still comes off, then the ring opening has been expanded to the point that it won’t ‘grip’ the mixer head flange. You can try to ‘crimp’ it at a few points around the ring with a pair of pliers so that it may grip better.
Finally, if none of these remedies work, you should order a replacement drip ring for which you’ll need the Parts List manual. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to make sure it matches your mixer.
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. Nos. 26, Planetary Drip Ring, which is the part you want to order.
Also, while your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your KA mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Jan 22, 2010 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
622 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
