Question about Celestion S80 Subwoofer
I connected the Celestion S80 with my Samsung Flat Screen TV and now I have lip-sync problem. Is there a solution for ?
Sound does not sync with lips on Samsung TV
that problem comes from the station not your set .
Nov 22, 2015 | Samsung Televison & Video
Lip sync my new viera has lip sync problems. It's a tx-l42ese model. Just had an engineer up to have a look at it. He replaced hdmi cable and made some adjustments and it was fine for an hour! Now it
Hi, Your TV is OK, it's your cable companys problem.
On some channels you will have this but not all. Beleive me it's not your TV. I have the same trouble.
Apr 07, 2014 | Panasonic Televison & Video
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I have a lip sync problem with a JVC LT-19DD30J LCD TV
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | JVC LT Televison & Video
VIZIO E470VA LCD HDTV audio and video are not in sync
Go to your On-screen Menu, go to settings, select audio, then select LIP SYNC. You can then adjust the amount of shift to synchronize the pix and the audio.
Sep 07, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
I have a celestion s80 active subwoofer, and when it is only plugged in to power, (no input) it lets out a soft whining sound that continues even after input is inserted. i have ruled out grounding issues,...
Dont remember which cap it is , but its 47 uf 35v, on one corner of the board. You can use a slightly bigger value and slightly higher voltage if thats all you can find. Check the two caps next to the voltage regulators, these go as well problem sorted!!!!
Sep 19, 2010 | Celestion S80 Subwoofer
HSL4229HDIP 42 inch LCD intermittent lip sync problem
Hi
Try Buying a aerial with a booster, u can purchase a inline booster at dicksmith or most large electrical stores.
kinds regards Kyle
u can reach me at
kyle-stelzer@hotmail.com
Apr 20, 2009 | Hisense Televison & Video
Lip sync playing ordinary tv
you need to have a sound speed equalization higher frequencies travel slow,
if you can buy a AV/RF CONVERTER the problem can finish
AV be connected to devices and RF to tv
this can over come that problem
Oct 07, 2008 | Philips Cineos HTS9800W System
Samsung 42
This is an issue that has been going on for some time with Samsung. This is call Lip sync. To fix this problem you need a software upgrade. If you are under warranty, we will change the signal board.
Best regards
CircuitCity
Oct 18, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Sounds don't align with lip movement
if you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
Jun 15, 2007 | Westinghouse SK-26H240S Television
Open Questions:
See all Celestion S80 Subwoofer Questions
Celestion S80 Subwoofer Logo
47 people viewed this question
Top Celestion Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Robert Rankin
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
