Pace 2600c 1 digibox version 3.5.3 upgrade to later version
Pace 2600c 1 digibox version 3.5.3 using it in spain can i load the latest version 3.7.6 on
    President:
  • 803 Answers
Yes you can
Posted on Oct 05, 2009
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Tip
Force the Upgrade of your SKY + firmware at the touch of a button
This applies to all PVR2 and PVR3 Amstrad. Pace and Thompson SKY+ units you Sky installer may do this for your it is simple to do;
HOLD THE BACKUP BUTTON WHILE YOU POWER ON THE UNIT
the TV and SKY+ will look like this during the upgrade please do not power down during this time as you will almost certainly kill your unit I always connect my Belkin UPS prior to a forced upgrade just to make sure it is always best to make sure that it will not fail during this process.
Notice that the lights on the unit this one is a PACE type PVR2 the REMOTE MESSAGE and ONLINE LED's are all illuminated as well as the POWER.
I had an old PACE box that had been used for the last 8 years that was still at v5.04d given to me last month I forced the upgrade and it took it to the latest version v5.07u this may not sound that important but there are some firmware versions especially for the AMSTRAD PVR2 unit that will cause audio lag and loss on certain channels (Virgin1, CN and CH4).
After the upgrade has completed I suggest that you check which version of software your unit is now using;
1.Press the Services button
2.System Setup menu
3.Press Option 5, 'System Details'
This shows the same unit 9F2106 before and after the upgrade the smudged info is the viewing card number etc.
on Dec 10, 2009 | Audio Players & Recorders
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
Hi, We have lost a lot of channels on our Pace dv3 digibox during the digital switchover in our area. Most of the advice I can find online is for a Sky+ digibox, rather than ours. Ours is just a 'Pace...
normally a factory reset would work other than that have you tried just re-scanning it as that would normally pick up channels that have been lost
Apr 22, 2011 | Televison & Video
HOW CAN I PRINT A TEST PAGE FOR MY KODAK ESP 5250
To print a test page:
  1. Make sure you have the latest version of firmware
2. Load8.5 x 11-in. plain inkjet paper in the paper tray. 3. Dothe following steps depending on the printer: ON ESP 3250, 5250, Office 6150 or 7250:
  1. On the control panel press Home.
  2. Select Maintenance, then press OK.
  3. Select Print Test Page, then press OK.
  4. Press Start.
  5. Wait for the test page to print.
For the 5000 Series Printers, a diagnostic sheet is usedinstead of a test page. To print a diagnostic sheet:
  1. Make sure you have the latest version of firmware. See How do I upgrade my all-in-one printer with the latest version of firmware?
  2. Load 8.5 x 11-in. plain inkjet paper in the paper tray.
  3. Do the following steps depending on the printer:
ON 5100: 1. Press and hold Quantity + Copy. ON 5300 or 5500: 1. Press the Menu button. 2. Scroll down to PrintDiagnostic Sheet. 3. Press OK. 4. Press Start. Wait for the test page to print.
Nov 20, 2010 | Kodak Office Equipment & Supplies
Very slow opening any thing loseing photos and unalbe to open games like farmville and cafe losing gifts please help
Just upgrade your internet browser to the latest version of Mozilla Firefox. Facebook site works and loads best with Mozilla Firefox.
After that install or upgrade your Adobe Flash Player to its latest version. Version 10 is highly recommended.
Let me know if that help solve the problems.
Please comeback and rate this solution.
Thanks for using Fixya.
Aug 24, 2010 | Facebook Computers & Internet
Hi, i have a pace sky digibox box switching itself off
Well every time you switch off the power the digibox returns to the factory default settings. The power must be maintained to keep those settings. There may be another brand that has battery back up to maintain the selected channels. Check with your owners manual to see if yours does have that feature. It continues to draw a very tiny current as long as it is plugged into power. There is no solution except a battery back up or leave it plugged in all the time.
Zashiban
May 31, 2010 | Televison & Video
Please reinstal norton all in one 360
uninstall the older version through add/remove programs http://spftrl.digitalriver.com/pub/symantec/tbyb/NAM/N360S300EN.exe
use this link and download and install the latest version
Feb 18, 2009 | Norton Internet Security 2005...
Intel cpu ucode loading eroor
You can upgrade your bios, you just need to visit the motherboard manufacturer site where you can download the latest bios.
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1276&modelmenu=1
You can also try to reset the bios first, you can reset it to default settings and if that will not work then you can upgrade the bios.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
and you can also check this site regarding bios upgrade
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Mar 21, 2008 | ASUS P5PE-VM Motherboard
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
