Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Water leaking and coffee dry
All of the water is leaking into the drip tray and the coffee is very dry in the dregs tray. No coffee at all comes through the SBS brew unit. The same also happens with the hot water / steam tube - nothing comes out with either choice of steam or hot water. I've cleaned the brew unit thoroughly (including all of the screens), but still can't find a solution to the problem.
    President:
  • 1,618 Answers
Sounds like the boiler is blocked, and machine needs to be descaled. Try this first remove the parnello if your machine has one on the steam wand then using a paperclip clear out the end of the wand, that might be blocked. If it isn't then run the descale to clear out the blockage in the boiler.
Posted on Oct 05, 2009
I just received my brand new talea giro plus in the mail today. went thru the instruction manual and set everything up step by step. when i turned it on the very first time the red exclamation point is...
I had a similar problem. I opened and closed the water tank, the top coffee bean coffee and the dreg door several times. I even 'stirred' the coffee beans a bit. Finally, after simply taking the coffee bean cover off and putting it back on, the light went to green. Even now, several months later, I sometimes have to open and close everything to make the green light come on, although it seems to be getting better with age. (like me :-))
Apr 27, 2011 | Saeco Talea Giro Espresso Machine
My Saeco Incanto Deluxe occasionally overflows with dregs and water under the machine prior to the "dreg drawer full" message being displayed. Is there a counter tray available for this machine?
Hi
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Apr 17, 2011 | Saeco Incanto Classic Espresso Machine
IT IS LEAKING WATER INTO AND UNDER THE DREG DRAWER. HELP!
Hi
Sounds like your drain is getting plugged with coffee residue. Remove your brew unit. There is an injector that has 2 orange o-rings in it in the back. That pocket below it is filling with water. There is a drain that is to the bottom left that goes into the drip tray in front. Use a prob of some kind that is about 12" long that you can stick down and forward in the drain pocket. Work it towards the front and you should open the drain again. it fills with oils, so use some hot sudzy water and clean it out.
Mar 28, 2011 | Saeco Royal Professional Espresso Machine
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
The tray below the coffee cup holder has coffee in it all the time. is something leaking? love our machine
HI
The coffee residue is the result of the machine relieving its pressure into the drip tray. When it relieves its pressure, a little coffee residue with some water is released also, otherwise you would have an explosion of coffee inside your machine. If you are getting dry coffee in the drip tray you are getting an overcharge and that is not good. If you get residue under the drip tray, you have a blocked drain in the back of the machine just above the center of the drip tray.
Jul 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Removing Saeco coffeemaker dregs container
The dregs container comes out with the drip tray. Lift up on the drip tray and slide it out. If this doesn't work then the brew group is out of position. Turn the machine off then on so that the machine goes through a self test. This will reposition the group allowing removal of the dregs container.
Apr 24, 2009 | Saeco Incanto Sirius Fully Automatic...
Water Leaks from bottom of machine as coffee is dispensed?
I had this same problem. Open the front door, remove the dreg drawer and then remove the brewgroup. In the back you will see a pipe sticking down with an o-ring gasket on it. Below that is a channel and a little opening where rinse water is supposed to flow into the front drip tray. It gets clogged with grounds pretty easily. I filled a hose with some water and stuck it down there and blew through it until you can see water come out the front hole. It's a little hard to describe but I hope this fixes your problem, it did for me. I just have to do it once every couple months.
Dec 07, 2008 | Saeco Vienna Digital Coffee Maker,...
Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
231 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
