Have an NTSC sony kdl42s4100 lcd tv which I bought in Canada and I have a Panasonic sc-bt200 home cinema blu ray system when connected via HDMI PAl blu ray discs work fine but normal dvds are only sound and message on TV invalid format.
  • 4 more comments
  • howardgirls5 Oct 05, 2009
    How do I lower the resolution on the Tv it is set to auto and have tries adjusting as low as 480P but still nothing
    I have adjusted the resolution as low as possible and still nothing
    dont think so bought dvds in store and work on anything else just not lcd tv
  • howardgirls5 Oct 06, 2009
    Have changed setting on dvd Player for tv signal as NTSC the player plays BLU Ray PAL perfectly but still wont play normal dvds
    not having much luck and going to update firmware tomorrow but was hoping for some more help. just to make sure PAL blu rays play fine but not ordinary PAL dvds only sound and tv says invalid format tv is Canadian and broadcasts in ATCS which is NTSCs digital signal
  • howardgirls5 Oct 07, 2009
    I have checked tv is compatible up to 1080p and even though blu ray works perfectly tv still says invalid format for normal dvds. How can i check of I can update codec????
  • 325 Answers
Hello Howardgirls5,
There are several things you can try to sort this out. The first thing you could try is the following web site
http://www.dvd365.net/
if you look at the top of this web site and click the link ' CODES' you could then look up your model number for your Panasonic blu ray player. If this is not listed then you could try some of the ones listed if they dont work you could keep checking the site until this appears.This would unlock your DVD player to play any region. Fixing the problem.
the other option. are the normal dvds the correct region what I mean by that is your blu ray DVD's will be pal 2 etc are the normal DVD's the same.
There may be a compatibility issue between your NTSC sony and the Pal DVD's they run at a different speed. Most of the newer TV these's days allow you to change the TV from NTSC to PAL so it may be worth looking from the MENU option or your handbook to see if this Can be changed.
I do hope this has help
Cheers
Little Dish Fitter
Posted on Oct 07, 2009
  • 19,396 Answers
Lowering the resolution has nothing to do with PAL/NTSC settings.
You need to change Video settings on Panasonic player to NTSC, or to change video settings on TV to pal.
Play with settings menu and adjust PAL/NTSC settings.
Posted on Oct 05, 2009
  • 3,741 Answers
Try rechecking all wire connections for proper placement and fit too and from the tv.
Try adjusting the video format on the DVD, flip through 480p and 1080i. See which format works best with your tv.
the tv and the unit both asre only compatible up to 1080i. This player's default display setting is 1080p. So, I simply did some problem solving and hooked it up to my main TV in my living room and changed the settings to 1080i.remove and hook the wirings back to the TV and check out on 1080i. try it couple of times this will help.
thanks.this will help.please do rate the solution,.thank you for using fixya.keep updated.
Posted on Oct 06, 2009
  • 4,924 Answers
This is cause by the blue ray system ...its reading only classic DVD format and blue ray disks ...the ones that have only sound and so ...are avi , mp4 or other like this divx etc...and for this ones you need to have special codecs to decode format ....if the system supports updates...it might be possible to load codecs and to work ...but ..Im not sure that it will .so ...a divx player it needed for to see all kinda disks ...
  • 5,138 Answers
It is possible that new blue ray does not reconize regular DVDs I do know that when VCRs were the Biggest thing on Market Alot of them had Nothing wrong with them they would not play boot legged Tapes, So this maybe what is happening on your unit.Will not play cheap DVD Disk.
  • 813 Answers
Make sure that the video cable is properly connected to the correct slot. Blue ray DVD's are full HD compliant and have high resolution whereas simple DVD's are not full HD compatible and have low resolution, so you might need to lower down the reolution of your TV. Check the manual.
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
My panasonic sc-bt200 wont play the 3d version of a christmas carol so were can i get the firmware to update it
The SC-BT200 is not a 3D Blu-ray player. You cannot play 3D Blu-rays on it. To watch 3D Blu-rays you need a 3D Blu-ray player, a high-speed HDMI cable, a 3D TV and compatible 3D glasses.
Nov 05, 2010 | Panasonic SCBT200 Theater System
PANASONIC SC-BT200 UNLOCK REGION CODE
Google for "Panasonic SC-BT200 Region Free
Also see
"http://www.avforums.com/forums/blu-ray-players/885440-blu-ray-player-multi-region-hex-codes.html"
Some Blu-Ray players will need a hardware mod to be region free.
Feb 05, 2010 | Panasonic SC-BT200 Home Theater Systems....
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
