Question about Hotpoint Dryers
There is water coming out from underneath - Hotpoint Dryers
  • Hotpoint Master
  • 7,482 Answers
Sounds like the problem is with your spin cycle of the washing machine, the clothes you put into the dryer should not be that wet that they are dripping water.
Try to spin the most of the water out of the clothes first using the washer.
You did not say if the dryer was heating or not...I have to assume it is heating.
I would try this solution first.
Good luck,
I hope this helps
Posted on Oct 05, 2009
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Water puring out underneath Gaggenau coffee machine
The water in unit is fed via a hose to the heating element. If the hose is broken or disconnected the water never reaches the element and spills out the bottom nice and cold.
If you remove the bottom panel the problem will be instantly obvious.
OR put water in unit and see where it comes out of!!!!!!!!!
Aug 30, 2015 | Gaggenau CM 200-630 Aluminum Espresso...
Water leaking from underneath my delonghi ec330s
There could be a loose hose, or a hole. Try to call the number the expresso came with.
Feb 08, 2014 | DeLonghi EC330-s Pump Espresso Maker
Hi My karcher k3.65 jubilee is leaking water when the pump is switched off from underneath
Hi This could be just the water inlet channel broken or split. You will need to remove the yellow cover via the screws at the back of the unit and then connect the water hose to see where the leak is coming from. If the water comes from underneath the pump then you will need a replacement pump seal kit of which you can purchase on the Internet.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Bissell 2xs
THE JETS UNDERNEATH THE MACHINE THAT SHOOT THE WATER OUT ARE PROBLY CLOGGED WITH DETERGENT. Get a pin and try to clean them from underneath the machine . Ten put some hot , hot water in and wait about 5 mins. then try it out.
Dec 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water is leaking underneath my Solis Master 5000
The only thing that comes to mind is the drain behind the brew unit under the white plastic valve.
Jul 09, 2009 | Coffee Makers & Espresso Machines
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Water coming from underneath Jenn Aire refrigerator
sounds like your drain holes plugged its behind back panel in frezzer
Mar 18, 2009 | Refrigerators
Dryers Logo
54 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
