Oil leaked from rear projector tv's central projector
I have a telefunken rear projector tv and oil leaked from the green color central projector, where can i get this oil and what is its function. can the projector work without it?
    President:
  • 788 Answers
The substance that you are looking at is ethylene glycol, which is better known as anti-freeze, but it is optically clear. If it leaked on to a circuit board, this is not a good sign. I have not been able to repair a set that has been contaminated with this fluid. If your set still works you can replace the fluid and the set will be fine, do not run the set without this fluid as it will cause the CRT to overheat and may crack.
I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about type of fluid that you need. I think it is referred to as CRT coolant, and is sold by the bottle.
I hope that this helps
Thanks for using fixya
If you need any further assistance please respond to this post.
asnowman
Posted on Oct 07, 2009
2 Suggested Answers
jomabug76
  • 1148 Answers
SOURCE: rear projector screen has only green and red
in the menu it should have color convergence,,try that
Posted on May 15, 2009
Sony model kp46c36 rear projection tv looks like its 3d vision use to correct itself now just seeing double and colors similiar to 3d
there is a problem with your convergence circuits which align the red,green,and blue colors this must be serviced again. sorry.
Jan 30, 2010 | Da-Lite Tensioned Director Electrol 89986...
My tv is showing blue when i turn it on i think my blue projector light is out?
i have a mitsubishi vs-60111 when i watch the tv as of last week the color is pale like green color or green,gray color the picture is sharp yet , i took front cover off the lights are still bright red , green and blue what can be the problem / joe
Nov 06, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
The color seems to be off. No red, and lots of purple. This is a Toshiba 57H81 wide screen big box tv. It was purchased in 2002.
Could be a bad board within the tv but it is sometimes the source input meaning it could be dvd player, cable/satellite box, etc causing the loss of color but it is unlikely. I have one of these tvs and they use red green and blue projectors to reproduce the colors so when the red projector fails then you get purple which is green and blue colors combined without the red. I have found it to be sometimes a bad connection inside the tv and I found insects such as roaches inside others. Using extreme caution when opening the rear cover of any tv due to dangerous and fatal high voltage. You might find that simply cleaning out the inside of tv and reseating all the connectors might resolve your issue otherwise you would have haul this tv to a repair shop where you pay half the price of a new flat screen lcd for just repairing this tv which will probaly have another color go out next month.
Aug 15, 2009 | Toshiba 57H81 57" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
Projector tv the red and green colors are not in sync
no its a convergence tube problem u shud change the green tube.
its the exausted one in this case.
Mar 15, 2009 | Philips 60PP9202 60" Rear Projection...
Cant get the redd green an blue projectors to line up correctly
you need to have the set reconverged,,,call a repairman to come out and reset the colors
Mar 01, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA HDTV HAS COLOR SPLIT ON SCREEN GREEN & RED
I HAD THE SAME ISSUE. I WAS LUCKY, MY TV WAS UNDER WARRANTY. THEY SENT IT TO BE FIXED. THEY REPLACED 2 CONNECTORS FROM THE PROJECTOR AND THE ON/OFF BUTTON. THE WIRES WERE NOT TRANSMITTING THE SIGNAL/ OR A SHORT IN IT. THEY REPLACE THEM ALSO. IT WOULD TAKE MY TV ABOUT 2 MINUTES TO TURN ON. THE COLORS WERE OFF. AND I HAD DOUBLE OR TRIPLE VISION. THEY ALSO REPLACE A FUSE IN THE PROJECTOR PART OF THE TV. THE FUSE ITS SELF COST ABOUT 275.00 WITH OUT LABOR. I DIDN'T PAY A THING I WAS ONE WEEK SHY OF MY WARRANTY TO BE OVER. EMAIL ME IF U THINK THIS HELPED. THANKS VERONICA.SANCHEZ@VETERANS.IDAHO.GOV
Jan 06, 2009 | RCA P52926 52" Rear Projection Television
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
