Question about Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
My shoprider creeps backwards on its own
My shoprider creeps backwards when the paddles are released, and no one aboard
Problem is your joystick is broken, I had the exact problem.
The plastic parts inside your tiny joystick is cracked due to abuse, likely someone pushed on it too hard, or banged it against something.. All it takes, is 50N, or 5 kilograms of force, to break it. It is a very delicate multi-axis inductive joystick made by Penny and Giles,
My advice is to replace the Joystick, which costs $200-300
A lot cheaper than replace the whole controller, which could cost $1000 or more.
Jun Lu
Posted on Apr 28, 2010
  • jamiejxlu Apr 28, 2010
    By the way, if you ever decide to have that joystick replaced, I would love to have the broken joystick for parts. I'll pay for the shipping cost.
    jamiejxlu at yahoo.com
I have a shoprider steamer. It wants to turn right when I push the stick forward or backwards. When it does go forward, there is a kind of jerking to it. If goes left fine. On and off problem.
The free wheel levers have got to be in drive mode. if one is in drive and the other side is not then the chair will try to go in circles. So if the right side free wheel lever is not in drive position then the chair will try to drive to the right because the right motor is not turning the wheel. The wiring to the right motor may have become disconnected.
Oct 10, 2016 | Shoprider Health & Beauty
Will not move has a clicking sound. batteries good
hi , what model shoprider is this ? okay have you checked the the wires coming from the controller to the motor ?
when you move the lever to go forward or backwards can you push the scooter ? if not the brake is seized, even if it clicks , that does not mean it released fully ?
no bleeping ?
Regards
Rob
Aug 10, 2015 | Shoprider Health & Beauty
How do i lift off the chair out of the shoprider cobra scooter
Lift the lever to turn seat and locate the release point. I think the seat is facing to the left of the scooter, then lift off. If not check for lock screw.
Oct 06, 2014 | Shoprider Health & Beauty
Hills no power
Sounds like it might be in lock mode or the free-wheel is on. if i remember correctly to unlock push the joy stick forward and hold, turn on the power hold in forwared for about 10 seconds then release turn of and on and should be unlocked. if you are in free wheel push the scooter forward or backward if it is easy to move then the free wheel is on put it to off. and power on and you should be sorted.
Aug 14, 2013 | Shoprider Health & Beauty
Older Shoprider 778b goes backwards when key is turned on, what's up? Check all connections.
The throttle set screw may have slipped a bit causing it to be a little bit on so when you turn the key on it moves forwards or backwards loosen and reset throttle bar and it should stop doing this.hope this helps Richard
Jun 22, 2013 | Shoprider Sprinter Xl3 Deluxe 778XLSBN
I have a 2002 Kia sportage 2wd the timing belt broke I replaced it my self. Engine started no knocks or anything but the timing belt creeps backward on the cams and rub the wall of the cover. What did I do...
A pulley or the tensioner isnt straight. Maybe why the old one broke?? you want to replace anything the belt touches while you have it apart. pulleys, tensioner, water pump.
Nov 16, 2010 | Kia Sportage Cars & Trucks
My father inlaw has a Shoprider Deluxe scooter, it is fully charge, all the fuses are good and the circut breaker is good. When we turn the key on it has fuel power and seems ready to go. We move the lever...
If you have followed all the trouble shooting guide in the back of the manual then it could be one of a few things. either the Wig-Wag control is at fault (the lever you press to go forward/ backward) or the control/drive unit is at fault. You will need to take it to a service centre to have it looked at or repaired. Shoprider are made by Roma medical and their web site is ;- http://www.romamedical.co.uk/ if you need a manual you can download from here.
Aug 09, 2010 | Electric Mobility Shoprider Dasher 4wheel ...
1700 Fortress Scooter won't go forward or backwards. The beeping is continual and the driving light comes on if you turn it on. The brake is in brake release mode. The battery is charged up? What is the...
Hi. Has the machine been in regular use before the fault occured? You say that the brake is in brake release mode, this mode is only ever used if you need to push the scooter by hand. It releases the brake on the motor, and also operates a switch to disable the controller from driving the motor. It does this because it would be to dangerous to drive the scooter with the brake disabled.
Move the lever back to its correct position. If it still does not work, then the disable switch might be faulty, or it might be a different fault such as a stuck brush in the motor.
Is this machine produced by shoprider ( Phisang ) of Taiwan.
Please let me know how you get on. Neil.
Jun 07, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
158 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
