Question about Amana ACD2232HR Side by Side Refrigerator
Freezer nor refridgerator is cooling
I arrived home from work and found water on the floor of the kitchen at the bottom of the refridgerator. There has been a clicking sound as if something turns on for a short period and then it turns off. Is there a part that can be easily replaced to remedy this problem or am I in the market for a new unit?
Please help to save Christmas!
wulfclub@aol.com
If the refrigerator has an ice maker or cold water dispenser, check the water line in back of the refrigerator. Be sure to unplug the refrigerator before checking anything. The feed line may be leaking. Repair is simple. Open the connection and wrap Teflon tape around the male end of the connection, then screw it back into female end of the connection.
Posted on Dec 22, 2007
Connect water pipe to refrigerators
READ COMPLETLY BEFORE ATTEMPTING. Should you not understand a portion of this either contact me or your local plummer.
You must have the valve for the refridgerator installed and then you can simply buy the needed compression fittings. This is available at the hardware store.
If you need a water line run from your water system there are kits at the hardware store (Westlakes etc) that usually stock a kit. Please note that this job can be very wet. You must have the water to whole home OFF before you begin this step!!! You need to clamp on a device included in the kit that goes to either side of the water pipe. there is a t-handle on this that after tightening you turn and it punctures the line. This is then never removed afterward. You run the plastic line up to and through the floor boards (assuming that you are working in the crawlspace or basement of your home). You must have the water to you whole home OFF when you do do this procedure!!!! Go to the kitchen and move your fidge away from the wall. You should have run the line match the outlet in the back of the refridgerator. The tubing will come through the floor and you must attach a valve that should also come in the kit. I have also seen these parts separately it differs from store to store. The valve is another compression fitting. attach it finger tight and then snug it up with a wrench. Watch for leak in all areas when you have attached the line to the refriderator. Review all work carefully. That means you need to go back under the kitchen and check that and the tubing for leaks. Here is a really good video by Big Tony. Great guy.
YouTube video about installing an icemaker
Sep 14, 2013 | Refrigerators
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
My Jenn-air refridgerator freezer section leaks water and builds up on bottom of freezer, defrosts then leaks out
sounds like you have a clogged defrost drain. when the unit self defrosts, the meltwater from the evaporator is supposed to go down a drain under evaporator, to a condensate pan underneath. when this drain gets clogged at any point, the water then drips into the freezer floor, freezes, eventually over fills the floor, and leaks onto kitchen floor. Do not try to snake out the drain, as it is plastic and usually not permanently attached, snaking can damage or dislodge the tubing, making problems worse. If you have a compressor, you can direct some compressed air into the drain to clear out any obstructions. Again, use caution against too much pressure, to avoid dislodging tube. Any reliable refrigerator repair service shouldnt charge much more than $100 to resolve this issue.
Mar 28, 2010 | Jenn-Air JCD2389G Side by Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water accumulating in the bottm of refridgerator
HI, Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Let me know if I can assist you
Thanks
Vic
May 17, 2009 | Refrigerators
Maytag Refridgerator and not cooling or freezing
sounds as if perhaps the overload replay has burnt up on the compressor, you can see it by removing the back cover, unplug unit and remove the starter from the side of compressor. if burnt up or melted youll need to replace it.. before you do i would call the manufacture with model and serial theyve experienced issue with some of these depending on model and serail they may cover repair
Mar 10, 2009 | Maytag MSD2651 HE Side by Side...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Kenmore refridgerator mo. #58251890,water dispenser will not stop
sounds like the switches are getting stuck and not releasing properly. the switches are inexpensive and relatively easy to replace if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana ACD2232HR Side by Side Refrigerator Logo
78 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
