Question about Rowenta DG-920 Iron
My iron is spitting water when i put steam on???
  • 832 Answers
It is overfilled with water. There's right measure for
your iron. It is specified in your manual. If no manual,
just fill it halfway and set your thermoswitch at a little
over half also.
Posted on Oct 05, 2009
  • rolando ingking Oct 05, 2009
    over half also.
4 Suggested Answers
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
  • 699 Answers
SOURCE: dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Posted on Feb 24, 2010
ZJLimited
  • 17970 Answers
SOURCE: Iron was leaking rusty water.
There will be a build up inside the hotplate where the water is vapourised. To clear this, refer to your manual or simply put on high steam setting, rest on it's heel, and wait for the indicator light to go out, then unplug, and hold horizontal over the sink. Press any steam boost buttons you have untill the iron is cold - and you just get water flowing out.
1.- Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2.- Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3.- Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4.- Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
Keep us updated.
Posted on Jun 30, 2011
How do i prevent my black and decker classic iron from spitting out how water after I have used it for a while?
Cheaper irons may steam better using distilled water. Minerals in water can cause this due to build up inside.
Oct 01, 2014 | Applica Black And Decker Classic Iron With...
Tip
My Steam Iron is Leaking Water
If you are having trouble with your steam iron leaking or dripping water, then this tip is for you.
The first thing to remember is that the wrong water can cause you many problems with your iron. If you are experiencing problems, one of the first things to try is to use different water in your iron. Steam irons need a certain amount of mineral in the water for them to operate properly, but too much mineral, iron, or organic matter can be disaster.
Too much will cause all sorts of problems. Brown water, white scale and other problems will come from the wrong water. The wrong water will also cause the iron to corrode and leak. Of course not taking care to store the iron properly will also cause corrosion and leaks. See my other steam iron tips on the brown water and white scale issues.
So, if you are having problems, you must first figure out if it is bad water causing the steam iron to spit the water out of if in fact you have a leak internally. Internal leaks are not repairable. They are often caused by a combination of poor water quality and not drying the iron properly before storage. Either of these can cause internal corrosion and lead to leakage. Make sure to use good bottled spring water and empty the iron before storage. Lay the iron horizontal for a few seconds while hot to dry the remaining water from the tank before storing on its heel.
Poor water quality can also cause the iron to spit the water back out the wrong places and give you the impression that you are leaking, when in fact you are not. Water that makes steam too rapidly, will spit out all over the place and will not want to stay in the tank and make steam. Before assuming that you have a bad leaking iron, try using different water first. You may also need to follow my tip for cleaning the water tank of your iron, so that the different water can be effective.
In short, the wrong water can cause many problems when it comes to steam irons. Do some experimenting before you buy another one only to soon have the same problems all over again.
on Jul 14, 2010 | Irons
The water that is spitting out when I press the steam button is clear and boiling hot. A LOT of water comes out.
Check to see the amount of water the iron requires. If too much is added it will spit water out can also come out of where the water goes in plus the holes the steam should come out. In order for the iron to steam the water must boil inside the iron. Check the instructions and see how mmuch the manufacturer suggests. You may have to fill it several times while doing the ironing. If there is no instruction try consulting the manufacturers web site for information on your make and model of iron. They should have instruction manuals available for download. If that is not the problem it could be cracked on the inside. Give the water adjustment a try first though a lot cheaper in the long run.
Aug 06, 2012 | Irons
Brown water spitting out of bosch steam iron
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Feb 03, 2011 | Bosch TDA8340 Iron
Dirty water in my iron
Feb 24, 2010 | Bosch TDA8340 Iron
Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Oct 06, 2009 | Rowenta Irons
I have a Sunbeam Steam Pro iron. Because we used normal tap water, there is a build up of calcified minerals in the water tank and the inside of the baseplate of the iron itself. The iron spits out these...
try putting straight vinegar in the water tank. Let it set until you see the deposit dissolved. Pour it out, rinse and use either some decalcified water or add a couple tsp. of vinegar to the tank each time you use it.
Sep 16, 2008 | Euro-Pro Steam Generator EP8001 Iron
Rowenta DG-920 Iron Logo
325 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
