Question about Olympus Camedia C-760 Digital Camera
I Can not see the date and time on displayed pictures although it is set in the camera. I am not sure whether this facility is available in this model. I refered to the user manual but nothing mentioned about it.
How do i set my camara to date and time stamp photos?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
To see whether your camera can automatically stamp the date onto the photos, refer to your manual. If you require further assistance, please reply to this post and specify the make and model of your camera.
May 24, 2014 | Cameras
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Feb 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Hi. My name is John and i can not get date on photos
Goto setting and turn on time and date..
Jan 09, 2009 | Canon Cameras
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Sd600
press the function button and change the picture size to postcard-there is only one setting that allows you to do date and time stamp-once you have rigth pic size setting-pretty sure it says postcard-go back to menu and you will see date and time highlighted on menu
Sep 06, 2008 | Canon PowerShot SD600 Digital Camera
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Aug 30, 2008 | Panasonic Lumix DMC-TZ50 Digital Camera
HOW TO DISPLAY DATE AND TIME
I checked the manuals and I believe that the function you want is not available within the camera menus.  The date, time, and lots of other information is included within each file that holds individual pictures.  The software you use to view and edit pictures should show the information to you and may allow you to manually add the date to the picture.  I use Photoshop Elements 6 (Mac) and it will allow me to put the date and time on a picture.  You might consider adding the date and time to the name of the picture file if you want a quick reference to the date and time
Jul 11, 2008 | Canon PowerShot S3 IS Digital Camera
Date and Time
Do you have the Camera User Guide~~~It tells you how to set it on p37
or
I found this on the Camera User Guide
steps
1.press the function/setting button
2.on the left side,there's a column displaying various features, and then you go to select the very last one, and then it will displays more options for you to choose(L,M1,M2,M3,S, postcard,etc), and then "postcard" is the one you should choose.
3.After that, go to "menu", go down to the very bottom on the option list, you will see that the "Date Stamp" is being set "off", go there and choose other options (date/date and time). This is how you can display time on the pictures.
Jul 09, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Display date & time on developed pictures
When you say it's displayed on the screen, do you mean while it's in playback mode, it's embedded there?
If not, you will have to put your resoltion in postcard mode and make sure in menu that your date or date/time stamp is turned on.
To get to your resolution settings, turn camera on to shooting mode, hit function/set button and arrow down to the bottom left corner where it will show your resolution (L,M,S, etc) and this is where you will find postcard mode.
This setting is the only one you can use date time stamp and will show up in prints, but only good for 4 x 6 prints, anything larger will not be good resolution, it will be pixelated because it's only enough quality for a small print.
Hope this helps!
Mar 12, 2008 | Canon PowerShot A460 Digital Camera
Olympus Camedia C-760 Digital Camera Logo
60 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
