Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Our Blanco dishwasher is not draining out.Drain is clear.
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
bluegreenash
  • 661 Answers
SOURCE: Not draining...hose clear
not really, it sounds like you have done all the basics,
Posted on Oct 09, 2007
ranger25
  • 72 Answers
SOURCE: DISHWASHER WONT DRAIN
Have you checked the drain hose??? It may be clogged to some degree or where it meets either the garbage disposal or t-tailpiece, whichever you have, or where it comes out of the water pump. Also, the impeller inside the water pump might look good but may be worn, and check for broken glass which is hard to see in the bottom drain area at the grate. Hope this helps.
Posted on Jan 28, 2008
reg501
  • 413 Answers
SOURCE: Kenmore Ultra Wash Dishwasher does not drain
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Posted on Jun 14, 2008
Our newish Blanco dishwasher BDW3458X sometimes doesn't drain all the water out either... it has H23 flashing but can't find any manual to tell me what this means. I appreciate all the answers others
I struck this problem recently and it may have been caused by someone leaning all over the buttons while it was running. I got around it by holding in the start/pause button for a couple of seconds. The timer went to zero and it whirred away for a few seconds. After this it was reset and has worked ok since.
wsr
Dec 29, 2014 | Dishwashers
I have a grinding noise when I first turn on my dishwasher what can I do to put this right
You've got something caught in the drain pump impeller blades. Remove the filter assembly on the inside bottom of your dishwasher and see if you can clear out the object stuck in the drain area.
Pro tip: Wet-vacs work wonders sucking out glass from drain pumps.
If you still can't clear it out, then you'll need to get under your dishwasher and remove the drain pump to clear out the debris.
Nov 15, 2014 | Dishwashers
Why kenmore elite dishwasher will not drain?
If it is connected to a disposal remove the drain hose and check for a restricted area in the hose or disposal this is common also check the drain hose for kinks be sure to elevate the hose before the drain area. If the drain hose is clear and the drain is clear then you could have a bad drain pump in the dishwasher.Most problems are a restricted drain or hose
Jul 22, 2014 | Kenmore 24" Built-In Dishwasher with...
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
GE profile dishwasher won't drain
Common cause of this problem is a partially blocked drain line. Disconnect drain line and make sure entire path is clear, including where it connects to the sink drain or garbage disposal. Also, make sure all screens and the drain area at the bottom of the dishwasher are completely clear.
Sep 21, 2009 | GE 24 in. Profile PDW7800 Built-in...
Water Won't drain fro the dishwasher model Blanco bfdw650s
If you "Lower" the hose to the bucket and it "drains" you are just using gravity to remove the water. The pump may be helping a little but if you raise the hose up and the water stops coming out, it's a good indication that the pump is bad. Unless the place you are attaching the hose to is plugged up, you need a new pump or a new impellor. Since the motor is good, try to get a replacement impellor, that the thing that moves the water. One other thing, you did say how well it washes the dishes? If the impellor is bad, it probably doesn't.
Sep 08, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Water doesnt drain from my blanco dishwasher at end of cycle
there are a few things you can do. First check your trap to make sure it is clear of obstructions. Next check your drain hose to make sure there are no kinks in it, or clogs. Also is it connected to a garbage disposal? If all else fails then worst case scenario is that your pump has gone out, in which case you need to schedule a repair.
Jul 19, 2008 | Dishwashers
I have a Blanco Dishwasher and the water will not drain away from the machine after it has completed a cycle, how do I get it to drain?
hi, there are 2 pumps on a dishwasher, it sounds like the drain pump on your unit is not working, it may need to be replaced. . if it is in warranty contact the manufacturer, if not contact a local appliance repair company. in the mean time you can use a wet/dry vac to get the remaining water out of the unit.
Mar 21, 2008 | Dishwashers
Oct 09, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
1,169 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
