When i turn it on stand by light flashes and thin horizontal line appears in the middle of the screen appears but picture does not come up. when i got this tv this was the problem and the repair guy i took it to said it was some kind of wire, when i got it back he had the color all red and was never clear however it would come on shortly after it would come up with the lin in the middle of the screen and if you turned it off and then back on it would come on. after a while I would have to turn it off and on a couple of times to get it to work and the sound started to get scratchey if I turned the volume up and down the sound would start working ok..I removed the rear cover and cleaned all the dust the inside of the screen and lenses. turned it on had to turn it off and on to get the picture working adjusted the color and it was the best picture ever. sound was still bad next time turned on was only horizontal line.. is it worth fixing?? How do I determine exactly what is bad and how do I order and replace it..
    Sergeant:
  • 247 Answers
Sounds like the tv is on the way out,multiple loose wires,bad solder joints,or failing components,could be causes,just cleaning it or attempting repairs could cause more damage,if someone has knowledge and its cheap,repair is certianlly still possible,but will need to be very carefull and delicate,when attempting,otherwise maybe a new set might be a better choice
Posted on Oct 05, 2009
Picture appears only as a thin, horizontal line...
chk vertical amp /vertical drive i/p from oscillator/power to it/power to vertical amp/chk dry joints-hot area/look at vertcal amp capacitors-swelling etc
Jul 04, 2009 | Akai Televison & Video
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
Apr 10, 2009 | Mitsubishi CS-27205 TV
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
