Question about Garden
How do you change from vacuum to blower on BVM240
2 Suggested Answers
  • 10 Answers
SOURCE: manual wanted
hi,
Try to find it here: http://www.down-servicemanuals.com/e/action/ShowInfo.php?classid=179&id=181505
Tks
Posted on Feb 28, 2012
After fixing blower motor it only blows out defrost
some a/c / heater actuators are controled by vacuum vacuum line may be pinched or broken when you did your repair,diesels have vacuum pump that suply vacuum for differant things,because diesel engine can not produce vacuum it self.if vehicle happens to have electric acuators then something may have been left unpluged or you may have blown a fuse
Aug 01, 2012 | Dodge Cars & Trucks
(blue) choke lever on my BVM240 has broken - any idea where I can source a replacement?
Try www.ereplacementparts.com or www.repairclinic.com.
Jul 18, 2012 | Garden
Manual wanted
hi,
Tks
Feb 28, 2012 | Garden
I have a McCullloch Garden blower powered bya McCulloch engine. the details on th Carb cover are:- N213 BVM240 99207N00116 The problem I have is that the engine will start but will only run for...
the line with the weight( filter) is the main line to the carby
the carby operates by a diaphragm driven by vacuum pulses from the rotating crank and piston movement
much of your problem will be from a diaphragm that has gone hard and not sealing properly
you can either replace the carby complete ( around ($25.00 on e-bay) or go to your local mower repair shop and get a kit to replace all the rubber in the carby or have them rebuild the carby
Apr 15, 2017 | Garden
Older leafhog don't know how to change over to blower instead of vacuum model Bv2500
Remove the vacuum tube completely from the bottom of the machine and make sure the impeller cover closes completely. Remove the collection bag off of the blower outlet. Now attatch the blower tube to that outlet on the blower. Done.
Dec 07, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
I can not get the Leaf Hog to swtich from vacumn to blower. Any suggestions?
it does not "switch"
The air intake becomes the vacuum with an attachment. The "blower tube" is then the vacuum exhaust.
the motor does not change directions.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 27, 2010 | Black & Decker Leaf Hog Blower Bv4000
How do i change black and decker leaf blower to vacuum
you have to remove the plate that covers the fan bla des intake than witch hoses some covers are spring loaded and just flip up
Apr 22, 2010 | Black & Decker Blower Vacuum Mulcher 1 Ea
Ve a McCullock BVM240 blower/vac It has excellent spark and fuel appears to be getting thru. I've put new fuel in, there is compression but it still wo'nt work I've looked at the carb and that seems ok....
try putting fuel straight into carb if it starts then its crarb fault dont put to much fuel in just a couple of squirts diaphram may be faulty in carb
Oct 22, 2009 | Garden
B & D leaf hog (blower/vac)
Check an see if a branch or something got caught in the blower an won't let it turn, if it hums that could be the problem
Nov 11, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Vacuum or Blower?
* Blowers perform the single, simple function of blowing material. * Blower/vacuum combinations combine the blower function with a vacuum feature. Leaves or debris can be directed into an attached bag, which makes this type of unit great for vacuuming leaves from shrubs. An additional mulching feature is available on some leaf blower/vacuums. Mulched lawn debris can be used in compost piles or bagged for disposal. Most convert easily from blowing to vacuuming mode.
Aug 27, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
