Question about Pioneer VSX-D498 Receiver
VSX-D498 Overload My Pioneer VSX-D498 receiver displays OVERLOAD for Digital input only, all of the three digital inputs - 2 optical and 1 coax - after a few minutes then shuts off.  Receiver works fine in stereo and Pro Logic surround modes.  Nothing has changed in the configuration for several months.  I haven't cracked it open yet to check for faulty solder joints or visually identifiable issues, I'm not sure how likely this is with the amount of use this unit has received the last eight years.  Appreciate any help you can offer.
  • 905 Answers
If you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Posted on Oct 07, 2008
No sound using optical cable connected to LG smart tv 60LN5600
Your receiver has 2 optical inputs. If you plugged in the cable to Input 1, you can select the "CD-R" Input on the receiver. Then use the "Signal Select" button to select Optical 1 (O1).
You can also use the "Input Select" buttons on the remote until the receiver says "Digital". Then use the "Signal Select" button to select Analog (A), Coaxial 1 (C1), Optical 1 (O1), or Optical 2 (O2).
Mar 08, 2015 | Pioneer VSX-820-K Home Theater Receiver
Optical inputs
You have to re route the sound from the samsung to the optical output. You do this is the audio setup section of the setup menu.
Jan 23, 2014 | Pioneer VSX-D498 Receiver
Hooking up phonograph to Pioneer VSX-D498
You'll need a phono pre amp and then you can connect to aux inputs.
http://www.google.com/search?q=phono+pre+amp&rlz=1C1CHMO_enUS514US515&aq=f&oq=phono+pre+amp&sourceid=chrome&ie=UTF-8#q=phono+pre+amp&hl=en&tbo=u&rlz=1C1CHMO_enUS514US515&source=univ&tbm=shop&sa=X&ei=Kv_2UMatJoOc9QSDr4CoAg&ved=0CGQQsxg&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.eWU&fp=a656d84bcd78ba72&biw=1360&bih=643
Jan 16, 2013 | Pioneer VSX-D498 Receiver
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-D307 Receiver - no audio using DVD inputs
Sometimes the default on receivers in dvd mode will be digital. Make sure you are on an analog input or just try an optical or digital coax out of the dvd player and be done.
Jul 06, 2009 | Pioneer VSX-D307 Receiver
Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Sep 19, 2008 | Pioneer VSX-D608 Receiver
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
VSX D511 No input select
I am getting no sound via my optical cable input. The back of the AMP says that the optical is TV/SAT but i can't change the input to digital it will only go to analog. DVD player is set to Bitstream all dvd options set to DTS, but still no sound going through. Any help would be apprecaited
Jan 29, 2008 | Pioneer VSX-D511 Receiver
Pioneer VSX-D498
Perhaps the unit isn't switched to 5.1 Maybe the movie wasn't recorded in 5.1 or if it was perhaps the recording was faulty. Try a known good recording to check the system. Check your outputs and inputs plus your speaker cables. Check the fuse if there's a seperate one for left and right, which there should be. Try swapping the front speakers to the rear and the rear to the front and see if the fault is still with the rear sound. BMW
May 15, 2006 | Pioneer VSX-D498 Receiver
Pioneer VSX-D498
silly Question John?? Have you or anybody changed modes on the reciver??? Not so silly as i've seem even a power do that. if not in the system then try unplugging for 24 hours and starting over again . let us know as maybe we can come up with more as we get more info. Good Luck
Pioneer VSX-D498 Receiver Logo
388 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
