Question about NAD Audio Players & Recorders
Lam afther the bulbs and lcd screen in a nad 510 cd player need to know if l can buy them in nz
4 Suggested Answers
  • 42 Answers
SOURCE: NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Posted on Sep 27, 2007
robotek
  • 1512 Answers
SOURCE: NAD 5425 CD Player display light out
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
Posted on Dec 12, 2008
SOURCE: I have a NAD 510 CD player with no display
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Posted on Jan 22, 2010
How do I connect my NAD cd-player?
If you have a receiver with a digital rca input, buy a good quality coaxial cable and connect it from the digital output of you cd or dvd player. The digital/analogue converters inside the receiver are almost always better than the ones in the cd player. If running cd to a stereo receiver, just use a good quality pair of rca interconnect cables. Red is right, White is left.
Jun 09, 2016 | NAD Audio Players & Recorders
What should l do my radio is in japenese and i speak english
Hi, i was looking for the same solution and never solved it completely. I was told you can get a cd to convert it however liaison with the company that produce the stereo proved fruitless and they were not able to assist me in getting the cd in NZ to do this. A stereo installer also mentioned knowing someone who did convert these to english in Auckland but they charge hundreds of dollars and i didnt think it was worth it when you can buy a gps unit from The Warehouse in NZ for $100 nz. Good luck, and if you do find a solution that works please do post here to let me know.
Apr 30, 2014 | Pioneer AVIC-D2 DVD Nav/6.5"...
Hi. Hope you can help me out here. Some1 is offering to sell me his NAD C521i CD player. Its been with him for 5 years. Is it wise to get it since it is already 5 years old (at least that i what the guy is...
This cd player sound great but have in mind it is fitted with NE5532 op amps in linedriver stage, but single trafo supply, and this player is a standard production line cd player. I owned one, i liked the NAD sound, and i think if you pay something like $100-$130 you will be happy. Also you ask if you shall be aware of something, in older nad cd player displays is sometimes defect, but easy to fix. Also the laser need to be adjusted often. (as in most cd players.)
Step from track 1 to the last traack fast and back to track 1 again, listen to music parts from track 1, track 4, track 10 track xx.
If the sounud is not choppy, if there are coming sound in both speakers and otherwise it sounds good then i think you can buy it without expecting major problems.
Oct 03, 2011 | NAD C521 CD Player
Display screen on 501 no longer working
Needs 2 new bulbs. Very common on older NAD players.
If you look very closely you'll see the display is infact working
but just not lighting up hence the need for new bulbs.
Jun 14, 2011 | NAD Audio Players & Recorders
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
Jan 04, 2010 | NAD C521 CD Player
Nad cd player cd541i noise
Hi...
That one is going to need Tech service.
I've worked on several of the NAD players.
Sounds like a focus or gain adjust needed.
Feb 14, 2009 | NAD C521 CD Player
NAD CD 5425 - No Spin - Sometimes
I've dealt with this type issue quite a bit.
Believe it or not the drawer belt needs to be changed.
If the drawer isnt drawn all the way into the unit...the disc motor wont spin and ....you get rejected
Dec 23, 2008 | NAD C521 CD Player
Sep 06, 2007 | Audio Players & Recorders
Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Aug 14, 2007 | NAD C521 CD Player
50 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
