Question about Ricoh Aficio MP1600SPF Copier
Windows\System32\spool\PRINTERS missing. The above files missing. No printers showing even after I restart the print spooler. I have also change the printspooler to automatic - no difference.
  • 541 Answers
You will need to reload your driver.
Posted on Oct 05, 2009
Can't print. local print spool not working
Try the steps below to clear the print queue and restart your print spooler:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 11, 2012 | Lexmark X5495 Printer
Tip
Printer Spoiler problem
<p><br />If the Print Spooler service fails when printing or when Windows starts or it can not be restarted, the usual reason is that one or more printer drivers is defective. The simplest way to resolve this is to remove all the drivers and reinstall them again.<br /> <p><br />If the Print Spooler service is not running, the Printers and Faxes folder will be empty and you can not use it to remove (or add) printers or printer drivers. <br /> <p><br /><b>Resolution:</b><br /> <p> <br /> <p><b>Windows XP:</b><br /> <br /> <p>If the Print Spooler service is operational:<br /> <p>1.<span> </span><span>Open the <b>Printers and Faxes</b> folder, Start-&gt;Printers and Faxes.</span><br /> <p>2.<span> </span><span>Delete all of the <span>printers</span></span> <br /> <p>3.<span> </span><span>Click <b>File</b>, Server Properties</span> <br /> <p>4.<span> </span><span>Select the <b>Drivers</b> tab</span> <br /> <p>5.<span> </span><span>For each entry:</span> <br /> <p>a.<span> </span><span>Select the entry</span> <br /> <p>b.<span> </span><span>Click Remove</span> <br /> <p>If the Print Spooler service is not operational:<br /> <p>6.<span> </span><span>Open regedit Start-&gt;Run and type regedit.</span> <br /> <p>7.<span> </span><span>navigate to <b>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers</b></span> <span>Under this key, there will be the keys Version-2 and Version-3 (one or the other of these may be absent - not a problem) the sub-keys under these contain the printer driver configuration information. Delete all the sub-keys inside Version-2 and Version-3, but <i>not</i> these keys themselves</span><br /> <p>8.<span> </span><span>Open a Command Prompt window</span> <br /> <p>9.<span> </span><span>Type the commands<br /> <span><b>net stop spooler</b></span><i><br /> </i><span><b>net start spooler</b></span></span> <br /> <p>10.<span> </span><span>Open Windows Explorer</span> <br /> <p>11.<span> </span><span>Navigate to <b>%systemroot%\system32\spool\printers\</b> and delete any files there. By default, this is where the <span>print spooler</span> stores print files.</span> <br /> <p>12.<span> </span><span>Navigate to <b>%systemroot%\system32\spool\drivers\w32x86</b>. Inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem) delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside w32x86, there may be other folders with names starting with "hewlett_packard", "hphp" (ex. for HP printers) or something else; delete these folders also</span><br /> <p><span>13. </span><span>Restart the <span>print spooler</span> (see steps 8 and 9 above)</span><span> </span><br /> <p><b>Windows 7:</b><br /> <ol> <li> Go to <b>services.msc</b> -&gt; stop the printer spooler service. <li> Get into windows /system32/spool. <li> Find folder named printer and delete the contents of it. <li> Restart the printer spooler service, check for printing. <li> Restart the computer and check it again.</li></ol> <p><span> </span>OR<br /> <p>cmd<span> </span>-- &gt; net stop spooler<br /> <p>del /q /f /s "%systemroot%\System32\Spool\PRINTERS \*.*"<br /> <p>net start spooler
on Mar 10, 2011 | Office Equipment & Supplies
Can't printer something about the spool
Can't print a cd on epson stylus 1400. The printing queue says paused.
right click on the print job in the queue, and click "restart". Other wise try this:
If you've ever had a print job hang, you're probably familiar with the Windows Print Spooler window. You get to this window simply by selecting the relevant printer from the Control Panel's Printers and Faxes applet (simply Printers in Vista). In the somewhat unusual event of a printer queue jam, you can go to the Print Spooler and simply delete the job. Sometimes, though, the system won't let you cut off print jobs that way: It marks the job "Deleting..." but never quite gets there, and you end up rebooting. But there's an easier way.
Open a command prompt (go to Start ' Run, then type cmd) and enter the following:
net stop spooler
del c:\windows\system32\spool\printers\*.shd
del c:\windows\system32\spool\printers\*.spl
net start spooler
In Vista you'll need to open an elevated command prompt by right-clicking on cmd.exe and selecting Run as Administrator. For those of you who remember batch files, use Notepad to save the four commands above as a batch file. I've named mine Killqueue.bat.
Dec 14, 2010 | Epson Stylus 1400 InkJet Photo Printer
How to clear the memory on a Samsung ML-2855ND?
In order to stop a stalled print job, perform the following steps in order:
  1. Stop the Print Spooling service.
    • Click Start.
    • Click Run.
    • Type cmd.
    • Hit Enter.
    • At the command prompt, type net stop spooler and hit the Enter key.
  2. Delete the stalled print job.
    • Open My Computer.
    • Go to C:\Windows\system32\spool
      • Delete any files you find in this folder (but do not delete any folders!).
    • Go to C:\Windows\system32\spool\printers
  3. Restart the Print Spooling service.
    • Return to the command prompt used in step 1.
    • Type net start spooler and hit the Enter key.
Sep 16, 2010 | Samsung ML-2855ND Laser Printer
Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Aug 19, 2009 | Lexmark Office Equipment & Supplies
Print spooler stops / Printers missing from machines
try C:\WINDOWS\System32\spool\PRINTERS
this path in spooler path
Jul 14, 2009 | Ricoh Aficio MP1600SPF Copier
I can't "delete" a document from the que
Option 1)
Click on start orb
services.msc
click ok
window.
stop
Option 2)
folder.)
It is located in:
00002.SHD
00002.SPL
Apr 10, 2009 | Lexmark International Z611 Printer
Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
Apr 10, 2009 | Dell 966 All-In-One InkJet Printer
Print Spooler Problem
Try this:
Start the computer in safe mode then delete all the files and the folders in the following two folders: • C:\Windows\System32\Spool\Printers
• C:\Windows\System32\Spool\Drivers\w32x86
Start Registry Editor. To do this, click Start, click Run, type regedit in the Open box, and then click OK
Locate and expand the following registry key:
View the list of subkeys. There should only be the following subkeys: • Drivers
• Print Processors
delete any other in this list
Locate and then expand the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors: • BJ Language Monitor
• Local Port
• PJL Language Monitor
• Standard TCP/IP Port
• USB Monitor
delete any other in this list then restart your computer.
Good Luck
May 24, 2008 | HP PhotoSmart C4180 All-in-One Color...
Ricoh Aficio MP1600SPF Copier Logo
157 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
