Question about Pentax *ist DL Digital Camera
Exactly the same!
Works fine if the flash is shut off though
Deivers tail light/brake light do not work..reverse works..when i lock my car the lights flash except for that one and the drivers light..headlights work fine though.drivers headlight bulb connector looks...
Could be a broken wire at the socket. Sounds like a burnt bulb also. Sometimes a burnt bulb will do the same thing as you are describing. Once you get this fixed, all should work. If flashing to quickly, replace the flasher stat unit!
Sep 04, 2013 | Volkswagen GTI Cars & Trucks
Using Ex Pat Shield, BBC progs no longer start and a notice, 'Task failed at step 0: config was empty.' (Or 'Task queue failed ditto' Everything worked fine just days ago.
I have exactly the same problem, same error message. I first noticed the problem yesterday (September 11). Error message appears when trying to watch live TV through iPlayer. BBC News Channel works OK from BBC News website. Live sports broadcasts work OK through BBC Sport website. I uninstalled and reinstalled Flash Player but it made no difference.
Sep 12, 2011 | AnchorFree Expat Shield
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
Hi, I have a Canon EOS Digital Rebel, and as of recently, it has been doing this thing where, on certain settings, i will go to focus the image, and when i click down all the way to take the shot, the...
Hey Lackster,
Error 5 is a problem with the flash. Long story short it thinks there is an external flash attached even though the mechanical pop-up still works. It is repairable.
Please let me know if you have any more questions.
Thank you.
Feb 17, 2011 | Canon Digital Rebel / EOS-300D Digital...
Sony Grand Wega KDF-E50A10
The lamp light does not have to flash on this set for it to be the lamp, and most likely it is just that, the lamp. These sets when the lamps get weak they will do exactly what yours is doing.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture shuts off
It seems as though the bulb(s) in your unit are about to go out. This is repairable/replaceable by calling your manufacturer. If you are still under warranty they can help you by possibly troubleshooting/replacement/referrals.
Aug 06, 2009 | HP Md5880n 58 in. HDTV
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Red Ring of Death crops up when my 360 gets too hot.
is it just the two lights on the the left? thats the code for overheated. i suggest putting it in a well ventilated area or get an intercooler.
Jan 09, 2009 | Microsoft Xbox 360 Console
Sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
Pentax *ist DL Digital Camera Logo
12 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
