Question about EliteGroup K7SOM Motherboard
Vga card resolution to low, need high resolution 1366 by 762, what type vga card i must looking for
  • 360 Answers
You are looking for a AGP 4x vga video card only, with some exceptions. Motherboard (1.5v for AGP 1x, 2x and 4x), but it will only work at up to the 4x that your motherboard is capable of. You may need to change your BIOS settings for AGP= 4x to obtain maximum performance from your motherboard and graphics card. AGP 8x cards run at 0.8v but some may permit 1.5v 4x compatibility. The AGP 8x cards have power issues that should be considered and really shouldn't be used. The best cards you should choose to use just happens to be the cards I have. NVIDIA-GeForce-FX5500 and FX5200 are about the best for your motherboard. Both can achieved the high resolution needed.
Posted on Oct 05, 2009
  • Richard Klein
    Richard Klein Oct 06, 2009
    DVI support up to 1366x762 resolution.
    Fx 5500 series is DVI support up to 1600x1200 resolution
    OpenGL㈢ 1.5 Optimizations and Support
    USE and UDA. ISA
    For your motherboard cards that match up to these standards and meet other requirement should be ok. Some VGA AGP 4X 8x ATI card fall into this category too.
    Graphic Core
    · Four parallel rendering pipelines
    · AGP 8X or 4X compatible
    · DirectX 9.0 and OpenGL 1.4
    · High performance 3rd generation HYPERZ III and Charisma
    Engine II(T&L engine)
    · Build-in HDTV decode and hardware Dynamic Compensation
    Technology
    · Dual integrated display controllers
    · SMOOTHVISION 2.1 (F-Buffer)
    · HYPERZ III increases graphics memory bandwidth
    · Lossless Z-Buffer compression (up to 24:1)
  • 329 Answers
High resolution is supported by high resolution monitors or LCD no matter what type of Video card are you using so first check monitor compatibility with the resolution
I cannot increase the res and have a yellow question mark on vga driver please help
you need to install a VGA card driver for the resolution to work, locate it in google using the type of VGA card you have in your PC, to find out what VGA card you have use Belarc Advisor(get it in google)
Dec 19, 2010 | Computers & Internet
My compaq computersceen says input not supported
i think your cpu settings you changed to high resolution. That resolution is not supporting by your monitor. If you have another monitor connect to that monitor to your cpu and change lo some low resolution. If monitor is not there try to boot in vga mode for that mode you need to press "F8" button on booting. It show you some modes select vga mode and boot and change the resolution and restart your system
Jul 05, 2010 | Computers & Internet
Recently i had purchased new 18.9 dell monitor but am not geeting high resolution
Getting high resolution on your new monitor are the best knowledge to identify if it is high resolution. Resolving your problem is see to it that your using such VGA Resolution of your built-in VGA or AGP VGA Card install with the software properly.
And use DirectX 9.0 or 10 version to help your graphic resolution works.
Sep 29, 2009 | ASUS A7V400-MX Motherboard
Unable to get 1440 x 900 resolution with onboard graphics.
Yes, through bios you can only select VGA but it wont have any effect on what you see on windows, so let bios aside. Is through Windows Display properties that you select all the different resolutions... (RIGHT CLIC YOUR MOUSE OVER THE DESKTOP, SELECT PROPERTIES AND LOOK FOR THE SETTINGS TAB ON TOP, MOVE THE SLIDER AT THE MIDDLE TO SELECT RESOLUTIONS) in windows is where you should have the latest drivers from ECS (now PCCHIPS) for your motherboard's onboard graphics. 1440x900 is widescreen type resolution, only available rather recently by new monitors that support it and so I guess it wasn't included in your original motherboard driver CD. Then it's a must to have the new drivers installed and the monitor's plug and play recognized by windows in order to attain the desired resolution from the card.
Any new AGP video card will be far better than the onboard type. DVI is just a digital type of conector and doesn't have to do with the resolution selection, but it will make the images in the monitor show a little better since there is no signal degradation in digital transfer through the monitor cable.
Jan 04, 2009 | Computers & Internet
Vga driver
i can find my vga dirvers
Oct 17, 2008 | Vga (CAT5-1000S/R) (EXTCAT51000)
Connecting lenovo t61 with samsung ln40a650
The LN40A650 supports 1920x1080 resolution from VGA. I know this because I've done it. It will also support lower resolutions, but certainly not higher. Drop your resolution to something low like 640x480, plug into the LN40A650, then up the resolution to 1920x1080. If this doesn't work it's 1 of 2 problems. It could be the refresh rate. Go to your display settings, click on Advanced, choose the Monitor tab, and set the screen refresh rate to 60Hz. If this still doesn't work it means your video card won't support that high of a resolution.
Sep 12, 2008 | Televison & Video
Resolution problem
Manufacturer's Specs Graphics Chipset Video Chipset NVIDIA GeForce4 MX440 More Info URL Manufacturer's Link Picture Quality Max Resolution
  • 1024 x 768 (XGA)
  • 1280 x 1024 (SXGA)
  • 1600 x 1200 (UXGA)
  • 2048 x 1536
  • 800 x 600 (SVGA)
Warranty Warranty Information 2 years limited warranty Compatibility System Type PC Slot/Port Type PCI Connectivity and Additional Features Interface Connection Video - 15 pin High-Density D-shell (VGA) Memory Installed Video Memory 64 MB Memory Technology DDR-SDRAM (DDRRAM)
Jul 25, 2008 | Nvidia Apple Geforce4MX (64 MB) Graphic...
Whats wrong with my pc?
You should upgrade all your drivers and set the VGA to high resolution maybe 1024X768 or higher. If can see the same problem maybe you should put and VGA add on card.
Jan 07, 2008 | Intel Motherboard
DSC T20 poor image problem
If you took the images at 8MP or 5MP settings, then normally you have a high resolution picture, was the picture clear at the cameras LCD monitor? As you said its like low res in your PC, please check the image file size 8MP resolution will be approx. 3Mb size, if its about that figure, then the problem is in the camera, if the file size is about 500K maybe its in the camera settings, PC cant affect resolution, unless you only have VGA card and monitor, hope this will help, thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
EliteGroup K7SOM Motherboard Logo
208 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
