Question about Panasonic Lumix DMC-FZ7 Digital Camera
When i switch it off and on it again a message appears
When i start it again a message appears on the screen that turn it off and start again
How do you "install" a firmware update to a tv??
On my Samsung, the message that a firmware update appears on screen, then you click Apply, it asks if you are sure?, you click Yes, and then a message says Don't use or switch off the television until the update is applied. A progress bar appears on screen, and then at the end, you get a message to switch off and back on again.
Feb 11, 2016 | LG Televison & Video
How do get a wash going when the message 'door' appears in the screen?
Replace the door lock. The little switch probably broke off.
Dec 17, 2014 | Washing Machines
Insert sd card again
At this time we recommend you use a different SD card and format it. SD cards can become corrupted and the camera may not recognize your card any longer.
Apr 13, 2014 | Panasonic Sale Lumix Dmc-ts20 Waterproof...
I switch the power on power light comes on fan starts as if to boot then nothing, no screen and no keyboard lights
Does BIOS messages appear, or is the screen absolutely black?
If you see BIOS messages and then black screen, you should go to BIOS and choose your boot devices correctly. If there is no screen do the following tip:
1) Turn off the laptop.
2) remove the battery.
3) click and hold power button for about 30 seconds to discharge the circuit from motherboard.
4) then install the battery again
5) and click power button.
See what happens. In many cases it helps.
If there is still black screen, you should check your laptops RAM. In many cases removing and then installing back the RAM helps.
Oct 19, 2013 | HEWLETT-PACKARD HP 630/P6200 Notebook
I have a Panasonic DVD recorder with hard drive (DMR-EX769). EVERY time I switch it on the following message pops up on screen : "A new DVB channel has been found. Start DVB Auto-Setup? Selective...
I believe there is an option to stop that. It's just finding out on what menu it is on. Some Panasonic machines have it on the FUNCTION MENU then press SETUP then press DIGITAL TV TUNING. It's often listed as NEW CHANNEL MESSAGE.
Selecting that will switch it off or at least the options for it.
It's probably caused by weak stations that get detected then drop out again.
Jun 16, 2017 | Panasonic Televison & Video
See White Screen + Nokia Logo + Failed to Start contact Retailer
Try formatting your phone and see if it works.
First make sure your phone is turned off.Then press the following buttons simultaneously (at the same time:
Power button + * + 3
This will restore and reformat your phone into factory settings. Hopefully your phone will be able to start again as if it were being used the first time from the box.
Let me know if it works,
Hope I have been of assistance to you,
Cheers :)
Sep 03, 2009 | Nokia 3230
Message on screen "turn power off and on again" when switching the camera on
this problem appears when the zoom motor starts malfuntion the remeady of its is to replace the zoom motor (if comopnent level repir is availble in ur area) other wise u have to scan complete lense block assembly. u didnt mention model no.
Jul 25, 2009 | Cameras
Error code f35 konica 7022
Turn on the main and sub power switches.
Keep pressing the
* button until the message
“Please enter service password.” appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press the key of the mode to be selected on the
screen. To return to the Mode Change Menu
Screen, keep pressing the
* button until the
screen appears.
When the adjustment ends, press
[1. Normal Mode] key and the basic screen will appear
Jul 14, 2008 | Office Equipment & Supplies
Can't switch on
lens of camera got stuck. tapp the camera while turning power on button.
May 27, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Cannot play this sound appears
the problem could be that tghe extenstion odf the music file could not be supported on tha phone so u must know what's the extenstions that ur phone support and for the silent mode while callin it maybe that u're choosin the wrong profile like:meeting,silent or another.... ... .. .
Apr 01, 2008 | Sony Ericsson Z310i Cellular Phone
Panasonic Lumix DMC-FZ7 Digital Camera Logo
65 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
